~$500 for desktop upgrade
jjkusaf
Time to retire my Creative Labs I-Trigue 3300.
I've been researching new speakers for a while and am burnt out. Help me make up my mind w/ the following in mind:
-85% gaming, 15% music (old rock like Grateful Dead, Allman Brothers, etc).
-Budget around $500 ... can go a bit over if it's absolutely worth it.
-Limited space. Desk is 60inches wide occupied by two 27-inch monitors on desk mount. Sub should be compact under 12inches deep/wide.
-Don't need Bluetooth, don't want headphones.
I've narrowed it down to the following (current prices, want new ... not wasting time on eBay, etc.)...
-Seems like a safe bet:
Kanto YU2 w/ Sub 6 - $430 (plus another 30 bucks for the feet).
-Seems like the best under $500 small speakers?
Vanatoo T0 w/ ?? sub - $399 +?? sub
-Or maybe these...
iLoud Mico Monitor w/ ?? sub - $249 + ?? sub.
-Getting out of my comfort zone...
QAcoustics 3010, Fosi Audio BT30D w/ ?? sub - ($169 + $90 = $260 + $$ sub)
-Shut up noob ... just get the Klipsch ProMedia 2.1 for $130
ZolaIII
Kali LP-6 V2 +Warfadale WH-D10 or some other sub that has high pass filter on lo level (RCA) output. That would probably be around 550~600 $\€ without cables.
bodhi
Get the best monitors you can get, stretching your budget to max. Get sub later.
It's a long game. Worst choice is passable monitors with not-quite-sub.
Rayman30
Do you have plenty of room for regular size monitors? and do you absolutely require a sub?
Ecksbocks
Stockholm
I would skip sub and get a pair Genelec 8010 or used 8020. These have a long life and you can always sell them later, I you like.
Count Arthur
How about the JBL 3 series:
It looks like the larger 6 and 8 models perform slightly better, so maybe start without a subwoofer.
Also, I have a pair of iLoud micro monitors. They are very nice sounding computer monitors and I use them all the time when I'm listening, at fairly low volume, to talk radio and podcasts, and they sound perfectly fine with music, but that tiny 3" woofer is going to struggle a bit at higher volumes.
AnalogSteph
.de
The Kali LP6v2s should be able to do it "barefoot" (they easily dig as deep as consumer 2.1 systems' subs)... the iLoud Micros are about the only 3" class speaker that go anywhere near as deep. Those will apparently sound to sound funny at higher levels fairly quickly as the DSP throttles back the bass response, but gaming is said to be much less affected than music. Unfortunately they don't have any explicit provisions for use with a sub, like the Genelec 8010s or my EVE SC203s would, so in order to have a sub reduce the load on them you'd have to set the sub much louder, measure the response and EQ the whole shebang flat.
