7Hz x Crinacle Zero:2 IEM Review
Rate this IEM:
    Votes: 4 1.2%
    Votes: 10 2.9%
    Votes: 36 10.4%
    Votes: 296 85.5%
Somafunk
Scotland
I am using Moondrop spring tips, fit perfectly in my ears and very soft outer which seals well and doesn’t cause any discomfort, quite shallow fitting which aids the bass response, you can feel a very solid in-head thump if you carried away with volume.
I’ve tried comply foam which inserted too deep affecting the bass response, tried a few Azla spinfits which I’m not too impressed with,
Currently got a few tips coming from aliexpress such as the Divinus Velvet , Tangzu Tang Sacai Balanced , Tangzu Tang Sacai Wide Bore , and of course I had to get more Moondrop Spring Tips
I have a Symphonium Meteor iem arriving this week and I want to make sure I have a nice choice of tips to get a good seal and fit/comfort.
Short nozzle iem’s such as the Zero 2, and my new Symphonium meteor benefit audibly from an ear tip that doesn’t insert too deep into the ear canal and I prefer wider bore tips as I feel they allow the iem to deliver sound as it was designed.
If I was you I’d get a set of moondrop spring tips, measure the width of your current favourite/best fitting tip and order the appropriate size.
phoenixsong
Interesting take as I heard some other members preferring longer tips for the Zero 2 :) Also, with the Spring tips, I do advise sizing up a little to retain a good seal due to their soft and shallow nature
Reactions: HQY
InfiniteJester
I ended up buying the EW200s for a little more than what the Zero:2s cost, and the comparison is absurd. Except in bass quantity, the EW200s are better at everything by such a wide margin that I cannot possibly see any reason to not prefer them if you are not a basshead: better fit, much better build quality, better imaging, better soundstage... They have such a naturality, an openness, a clearness to the sound... that I can only describe them as the anti-thesis of the bloated, claustrophobic and unnatural Zero:2s.
While it is true that they are bright-ish, it is very easy to apply an EQ to increase bass and decrease brightness at your taste without running into any apparent distortion issues:
EQ'ed to USound (I'm using this):
Preamp: -3.7 dB
Filter 1: ON PK Fc 20 Hz Gain 1.7 dB Q 1.000
Filter 2: ON PK Fc 86 Hz Gain 3.1 dB Q 0.500
Filter 3: ON PK Fc 730 Hz Gain 1.8 dB Q 0.900
Filter 4: ON PK Fc 1300 Hz Gain -1.2 dB Q 2.000
Filter 5: ON PK Fc 2000 Hz Gain -2.1 dB Q 1.300
Filter 6: ON PK Fc 5000 Hz Gain -3.4 dB Q 2.000
Filter 7: ON PK Fc 6500 Hz Gain 6.1 dB Q 2.000
Filter 8: ON PK Fc 8100 Hz Gain -8.4 dB Q 2.000
Filter 9: ON PK Fc 9700 Hz Gain 2.8 dB Q 2.000
Filter 10: ON PK Fc 10000 Hz Gain 3.9 dB Q 2.000
EQ'ed to Oratory 1990 (if you really want to mess with the treble [I don't]):
Preamp: -3.8 dB
Filter 1: ON PK Fc 94 Hz Gain 1.7 dB Q 0.700
Filter 2: ON PK Fc 700 Hz Gain 1.8 dB Q 1.000
Filter 3: ON PK Fc 1600 Hz Gain -2.5 dB Q 1.200
Filter 4: ON PK Fc 2500 Hz Gain -0.2 dB Q 2.000
Filter 5: ON PK Fc 4900 Hz Gain -3.0 dB Q 2.000
Filter 6: ON PK Fc 6400 Hz Gain 4.5 dB Q 2.000
Filter 7: ON PK Fc 8100 Hz Gain -8.5 dB Q 2.000
Filter 8: ON PK Fc 9800 Hz Gain 5.3 dB Q 1.000
Filter 9: ON PK Fc 10000 Hz Gain 6.3 dB Q 2.000
Filter 10: ON PK Fc 12000 Hz Gain -9.4 dB Q 2.000
They are just excellent. It is amazing what you can get for that little money. The tips they come with are small and bad, though; but still better than the colorful jokes the Zero:2s present as tips.
Reactions: HQY
muza_1
Mexico City
I guess it depends on the ears, the colorful tips from 7Hz are the ones I use for all my IEMs, after trying all the ones (SpinFit, Tangzu, Dunu, Clarion, KBEAR etc.) mentioned in this and other IEM threads this ones (red and blue) are the most confortable, silent (I don't hear my steps while walking) and I don't have to fret with them to get a proper seal.
HQY
Got mine 3 days ago along with that zonie cable. Running for 3 days and they are good enough for my use to listen to Tidal/Qobuz/Youtube via iPhone. I'm new to IEM but being an audio fan for 20+ years. I don't use EQ now and less likely in the future. Just casual listening and enjoy.
Music1969
Can anyone tell me what the sizes of included eartips are?
Which colours are small size to largest?
Its hard for me to tell :-(
Music1969
Clearly, this is a very good IEM for the price, but I am a bit dissapointed that EQ is needed to get the best performance. I have already so many IEMs, including the original Salnotes Zero, but it seems that the Truthear Nova, while more expensive, is stealing the show:View attachment 335315
Actually , looking at 5128, Nova needs the EQ, not this Zero 2...
mc.god
Roma, IT
You are comparing two different things targeted to different curves.
The Nova screenshot by @MacClintock is a 711 measurement targeted to Harman IE 2019 v2 while your screenshot is BK measurement target to Diffuse filed curve with an arbitrary 8 db bass boost, that you can change according to preference.
If your target is Harman Curve you have to compare Zero 2 to it, and this is the outcome:
and Nova clearly doesn't need EQ while Zero 2 does.
Grobbelboy
Nah, that’s diffuse field target. The Zero 2 EQ’ed to Harman with the filters that Amir provided sounds significantly better than the stock tuning.
[edit] In reaction to Music1969
MacClintock
I gave a like and know what I have stated previously, and when taking the Harman2019IE target, it is true that the Nova is more adherent, in fact the most compliant of all IEMS I know of. Please don't come with the scoring, it takes only 40Hz to 10kHz into account and the Nova is especially good and smooth in the treble.
Having said all this, being in possession of the Variations, the Nova, the Red and the 7Hz Zero 2, for the last weeks I was almost exclusivley using the Zero 2 and have zero motivation to change this, it takes away a bit of the ear gain of the 2019 target, which is pleasant for me. Amazing IEM, not even considering the price.
MacClintock
That is a feature and not a bug for many folks - including Crinacle, who has been vocally critical of the Harman IE target.
In fact I don't know if this is true. Looking at his and other sites, "his" supposed target is almost flat in the bass from 1kHz down, but no IEM he ever tuned has this (lack of) bass. So either he is lying about this or just not tuning any of his many IEM's to his proper target, which would be very strange to me.
Music1969
Would be a good response if you didn't show your ignorance about:
1. Coupler accuracy beyond 10kHz which is not a thing, less important for inclusion into a scoring protocol
What are rude reply
And speaking of ignorance , he did not make any comment about beyond 10kHz
We have 5128 data for that
2. The low importance of sub-40Hz for audio reproduction, and audio production.
This is even more ignorant
mikehoopes
Campbell, CA
I procured a custom TRRS 50mm cable with a clear plastic chin slider ("8share 2.5mm 0.78mm") for $26/11 days from an Aliexpress vendor.
https://www.aliexpress.us/item/2251832764723404.html
I specified no ear hooks, as they somewhat hamper fitment (pulling the top of the shell inward) and tend to be a tangling nuisance, with a slight loss of comfort at the bend. So with the new balanced cable, I'm gaining some theoretical headroom, but mainly the shortened length is more manageable with the Qudelix 5K application. The alternate ear tips and o-rings make the fit quite reliable for me.
Regardless of targets, I have enough (mild to moderate) sensorineural hearing loss (some age-related, some congenital) that I'm compelled to equalize all IEMs.
markanini
Scania
What are rude reply
Focus on your perception of my tone only if you don't care about facts. Otherwise read IEC 711 specs. Read "The Mixing Engineer's Handbook" by Bobby Owsinski which states that 40Hz is the target for monitoring exipment, not sub 40Hz. Most importantly trust Sean Olive who knows this already and applies his knowledge to his model.
Music1969
Why on earth would I do that when I have a real-time music spectrogram showing me high levels of sub 40Hz content for my music ?
How silly
Maybe you, Bobby and @Sean Olive only listen to Tracy Chapman :p (that's a joke Dr Olive will get)
markanini
Scania
How silly
Because you are using the wrong tool just to reinforce your bias. If you were interested I'd tell you there exact tool to test your ability to hear content below 40 Hz in real music.
Music1969
I can apply a high pass filter while music is playing - on and off
You don't seem to be aware that modern popular music has high content sub 40Hz
I don't think Bobby mixed any deadmau5 lol
MacClintock
I don't know about everyone else, but I will side with Sean Olive on setting the limits that way into his model.
The ignorant, like always, is you. Independently of how easily or accurately or whatever the response can be measured above 10kHz, it is still there and there is music material (especially overtones) and it matters. And many IEMs, for example the Truthear Zero:Red, show wide swings in this region, while the Nova (especially with foam tips) is smooth. I checked this as well with tone generator. So the fact, that this region is not included in the scoring system just shows how inaccurate it is. And if you would be knowledgable, you were aware of the fact that Sean Olive himself is not a fan of taking it too literal, it is just there for a ballpark number. Furthermore, there is also valid content in the sub 40Hz region, at least in some music I listen to. And I want to hear it properly.
