AB(x) testing of Power Amplifiers
pma
Prague
I had to do it. Once again I was convinced that I hear a difference in a sighted test, so I had to prepare a properly level matched A/B test. Two amplifiers, both of 2 x 50W/4ohm rated continuous sine power.
  • conservatively designed class AB, with acceptable distortion up to 0.02%/1kHz/4ohm/30W
  • class D TPA3255, AIYIMA A07
The task was simplified as the AIYIMA has its own volume control, so there was no problem with level matching. I draw the simplest test circuit that would connect/disconnect both wires feeding the speaker, not only to prevent any ground loops, but also for the reason that AIYIMA has BTL output with both binding posts “Live” - none of them is grounded.
The relay used was just what I had in stock – a 6 amps TYPE6013 with 3 switching contacts. Hopefully this type can be disassembled and the first think I had to do was to brush and clean the contacts, as their contact resistance was creating non-linear distortion, which must be avoided.
So this is the photo of the DIYed A/B test circuit.
I made a test with 2 different music samples, Beethoven's No.7 Symphony (Wiener Philharmoniker, Simon Rattle) and Rolling Stones, “Anybody Seen My Baby”. Before the test, the level was matched with a 1kHz sine and with the pink noise, measured at speaker terminals. Matching at about 0.07dB.
So what? Though I did not expect it, there was a difference. The class D was punchier, with better impact on bass and better distinguishing of instruments, and also more dry. The class AB was more on the mellow side, but tending to blend, melt. Average power was about 4W on the Stones sample. The symphony has much more difference between loud and silent parts so speaking about power is difficult. No clipping, of course.
Tangband
Sweden
Very interesting !
Is the more ”punchy” sound from the Aiyima a07 a coloration of the sound, or is it actual sounding better, more natural ?
I have the Aiyima a04 (tpa3251) and I have the same sound experience as you have, when compairing a04 with different class A/B amplifiers.
pma
pma
Prague
Very interesting !
This is difficult to say. As a next step, I want to measure distortion of current that flows into the speaker, in other words speaker/amp interaction. At the moment, I only have a comparison of THD(+N) vs. frequency into 4ohm resistive load at 1kHz. As you can see, the class D under test has lower distortion at 1kHz than the class AB under test. I am not saying this is the main reason, however it is a measurable difference.
Murrayp
Napier, New Zealand
Was the test blind? Likely there is such big differences between the amps that this doesn't matter. An easy way to make the test blind (to most intents and purposes) is to use a rotary 12 way switch and connect every second pole to close the relay. Spin the switch with you eyes closed to a random position and try to ignore any hints (relay sound etc) - then toggle back and forth between two positions (without knowing which is which). Once you have made your mind up - check to see whether your assumption matches reality. Rinse and repeat (many times).
My guess is with this pair of amps you'll get 100% accuracy - so no need for many tests. But with more equivalent amps it may be more interesting (eg quality high power AB vs class D). I recently tested speaker leads this way and found more to it than I expected (could identify blind the effects of very small resistance differences in the leads - gave tonal variations of just 0.14dB). Most amps likely have bigger output impedance than the speaker leads did so I'd expect them to sound different in my case (ie with fairly low impedance speakers).
dominikz
This is in line with my thinking too - if the amps that are being compared have significantly different output impedances, the difference in FR deviation with a complex load may be audible - however they could also fairly easily be linearized with EQ.
@pma - Very interesting test - thanks for taking the effort and sharing the results! Have you thought about doing FR measurements of both amps with the same speakers connected, to see if there's significant differences in response due to output impedance?
direstraitsfan98
The results would be much different if you ran the test again on a speaker with a benign impedance load. Also you should not know which speaker is being used. What speaker was used for the listening test?
restorer-john
Getting worried about you Pavel.
Lots of subjective words. Class D...mmm. ;)
SIY
Alfred, NY
I assume you'll make recording of the outputs for ABX or other analysis? Frequency response into the load?
Reactions: pma
daftcombo
Is the FR in the audible range identical for both amps?
Reactions: pma
pma
pma
Prague
I think I have enough data to explain audible differences.
1) FR at speaker terminals
Interestingly enough the FR elevation of the class D amp (LC output filter) compensates for decay of highest frequencies due to inductance of speaker cable.
2) distortion at speaker terminals (behind the speaker cable)
class AB distortion at speaker terminals, 2V. THD = 0.0062% is at 400Hz.
class D distortion at speaker teminals, 2V. THD = 0.0034% is at 400Hz.
Conclusion
As always, we MUST measure the whole audio chain and not only a single component of the chain.
dominikz
Conclusion
Very nice! The FR difference definitely seems like it could be audible - around 0,2-0,3dB at LF, ~0,15 at 1kHz and more than 0,6 dB above 10kHz. So I assume one probably sounds slightly brighter than the other.
Makes me wonder though if the audible difference would disappear with some EQ to align the FR of the two amps. One could use REW to divide the two magnitude plots and then it should be relatively easy to flatten the difference curve with EQ.
pma
pma
Prague
Thanks for your feedback, there is a shift of 0.2dB dB added in today's measurement of FR (for better visibility), so the green plot (AB) to be shifted 0.2dB up. The remaining difference is mostly above 2kHz. I am posting D/AB plot and it is really the effect of the LC filter of the class D, as I had shown in another threads. Re sound, as described in the post #1 of this thread.
solderdude
The Neitherlands
Now that you know the FR deviations you can shelve the offending one so those differences are minimized.
In that case... can they still be told apart ?
Is it an FR thing only ?
boXem
Europe
Inductance of speaker cable or inductance of speaker itself?
Are there "official" plots of the speaker that can be taken as comparison point?
That would be another interesting experiment.
Tangband
Sweden
So watch the plots, dear John @restorer-john ;). I am trying to be open-minded, though it may be tough :).
Hmm... does the better ”punch” and impact on bass depend on the slightly different response in the treble area do you think ?
pma
pma
Prague
I promised in another thread to measure distortion of current flowing into the speaker, for both amps. So here it is, nothing much new revealed. The measurement was not straightforward, because both output terminals of the class D amp are floating and the shunt (0R22) voltage of small value is thus floating with high CMV. I will probably try transformer isolation later, this was a "standard" balanced input, however the resolution was limited due to input divider scaling with respect to CMV.
This is the current vs. frequency plot and it reflects inverse impedance plot
class AB x class D current distortion (removed because of low measurement resolution)
