There you Go... the Reason why I sold my Fosi V3, Aiyima07 Max sound Amazing with Muses02 rather than Sparkos ss3602Aiyima A07 vs A07 Max stereo vs A07 Max mono x2
AIYIMA A07 MAX - KING OF SPEED & PUNCH
Remember the enclosure is the heat sink. Not sure if having the board open will make it better or worse,Inductor temp, amp idle no signal in, 48v supply, room temp 22*C. Quite hot right?
On both dual inductors? What is your power consumption?. 30degC above ambient temp do not seem excessive.Inductor temp, amp idle no signal in, 48v supply, room temp 22*C. Quite hot right?
These inductors do not direct contact with the cover. The picture is that I measured the temperature immediately after taking it off because I felt it was very hot beforeRemember the enclosure is the heat sink. Not sure if having the board open will make it better or worse,
I had 2 a07 max running side by side one with 36V and the other with 47V. The difference in temperature was significant. Lowered 47 to 42V and now there is almost no difference.
Both dual inductors have the same temperature when the amp does not have input signal. I will try to measure again when generating higher power levels at 4ohm load.On both dual inductors? What is your power consumption?. 30degC above ambient temp do not seem excessive.
Those inductors have aprox 10mOhm DCR, and can hold up to 7A before internal temperature increases 40Degrees.
I^2*R= 49*0.01=0.49W dissipation.
This would mean the amplifier outputs 49*4Ohm=196W per channel.
I asked the other inductor temperature to confirm is not the thermistor heating up the inductor. That thermistor gets very hot.
have you tried using a separate p/s for each amp?I have 2 of these amps in mono powered by 1 powersupply. I hear a noise through my speakers with the volume at max and no input. Even when I have only one A07 max on, I hear this noise. When I remove the powerplug from the other aiyima or I disconnect the rca from the other A07 max not in use, the noise is gone. So with only one aiyima in mono mode I have noise, when I connect both I have noise even when one in not powered on. I tried a different powersupply, with or without earth at the powersupply, connected the rca's with another source but nothing helps. Does anybody knows what's going on and how to get rid of it?
No I haven't. I had a 36v 7A power supply with my aiyima a07 but bought a quality 48v mornsun lof550 for the two A07 max in mono.have you tried using a separate p/s for each amp?
doug s.
you should try running each amp on its own power supply. (also try each p/s on a single amp connected in stereo.)No I haven't. I had a 36v 7A power supply with my aiyima a07 but bought a quality 48v mornsun lof550 for the two A07 max in mono.
Not sure if I understand correctly. But one way to find out is swapping RCA cables to see if the noise follows the rca cable, or also try swapping the amps to see if the noise follows on specific amp.I have 2 of these amps in mono powered by 1 powersupply. I hear a noise through my speakers with the volume at max and no input. Even when I have only one A07 max on, I hear this noise. When I remove the powerplug from the other aiyima or I disconnect the rca from the other A07 max not in use, the noise is gone. So with only one aiyima in mono mode I have noise, when I connect both I have noise even when one in not powered on. I tried a different powersupply, with or without earth at the powersupply, connected the rca's with another source but nothing helps. Does anybody knows what's going on and how to get rid of it?
Only one amp in mono or stereo is no problem. The noise is only there when I connect both amps in mono. Even when in that configuration one amp isn't powered on. When I remove the rca cable or power supply from one of the amps, the noise is gone.Not sure if I understand correctly. But one way to find out is swapping RCA cables to see if the noise follows the rca cable, or also try swapping the amps to see if the noise follows on specific amp.
Did you try each amp independently in mono? And then each one independently in stereo?.
I'm trying to figure out if one of the amps is defective. Also you can try a different pair of rca cables.
Because I asked here before ordering and it was confirmed as good.you should try running each amp on its own power supply. (also try each p/s on a single amp connected in stereo.)
and, i'd also recommend a separate p/s for each amp, even if there were no hum, and/or you get the hum issue sorted out. something like a pair of Mean Well HRP-300-48's would cost less than the single p/s you bought, if you shop carefully, and would have better amperage capacity per channel, as well as truly separate amps for each speaker. why share a power supply?
doug s.
you still need to try these amps w/separate power supplies when running mono, to see if this is the cause of the noise.Because I asked here before ordering and it was confirmed as good.
Because I wanted to try a decent power supply instead of the cheap AliExpress ones.
Because the mornsun lof550 is recommended on this forum and is used in different diy builds in this forum. Also to power one or more tpa3255 amp boards.
The RCA negative wires and power ground are connected. Try using different power supplies for each amp. You are having a ground loop.Only one amp in mono or stereo is no problem. The noise is only there when I connect both amps in mono. Even when in that configuration one amp isn't powered on. When I remove the rca cable or power supply from one of the amps, the noise is gone.
Used my nad t757 as preamp and tried with the preouts from my blueray player also to be sure my nad wasn't the problem.
agreed; which is why i made the suggestion earlier, and repeated it again. i'd imagine the op is a bit disappointed spending the coin on a nice p/s and having this happen. and, for me, even w/if no ground loop issue, i'd rather have two 48v/7a power supplies for two amps than a single 48v/11a power supply.The RCA negative wires and power ground are connected. Try using different power supplies for each amp. You are having a ground loop.
Let me tell you about something that happened to me like a year ago. I have an A/B/C/D speaker switch. 1 speaker cable set input and 4 speaker set cables output that you can control to play on output A, or B or both at the same time. It is basically to test speakers and identify differences on how they sound. Then I though what about if instead of using it as a 1 input and 4 output switch, I wire it as 4 inputs and 1 output. This way I can test up to 4 amplifiers and play on the same speaker set. Well...let me tell you It did not work. I was getting a loud ground loop no matter which amplifier I select. It turned out that all the negative wires were connected(even if I select none from the switches) and only the positive wires were affected by the switches I select.Only one amp in mono or stereo is no problem. The noise is only there when I connect both amps in mono. Even when in that configuration one amp isn't powered on. When I remove the rca cable or power supply from one of the amps, the noise is gone.
With all three Amps powered by a 48V5A supply, the 4Ω output power "at the knee" is:Probably has been stated elsewhere, but can I confirm that both the V3 and ZA3 will produce more watts at 4 ohms then the A07 Max run in mono?
Ah ok. Thanks!With all three Amps powered by a 48V5A supply, the 4Ω output power "at the knee" is:
Stereo:
A07 Max___140W
V3_________140W
ZA3________140W
Mono:
A07 Max___166W
ZA3________200W
