Great, we love a cheapskate at ASRI use a Sony STR-DA1200ES for one pair of three-way speakers. Going price on eBay seems to be about 30 - 150 euros.
A passive crossover can present a better ("nicer") load to an amplifier than using an active crossover before the amplifiers. The raw input impedance of drivers and box can be pretty ugly (not that crossovers always make it better). That and reduced cost and complexity (for the user) are the usual pros of passives that I recall. Obviously those issues do not apply to a complete active loudspeaker system (i.e. a box to which the user need only connect a line-level input from his source).
Unless you can compare speakers in your own room it is very difficult to have a really valid opinion, it is difficult enough when they are both in your room!
Really? The raw impedance of mid and HF drivers is mostly resistance with a small amount of inductance, so very easy. LF drivers have impedance changes at resonance, but those are generally an increase in impedance, and so pretty benign, and above resonance again tend to be largely resistive. Consequently, if anything, an amplifier connected directly to a driver will have an easier time than driving a complete passive system through a crossover.
S.
I was going to say something similar but less authoritative. Stereophile speaker reviews often show really difficult loads presented by passive crossovers, whereas individual drivers are relatively benign and, of course, require much less power from the amp in the first place. Active systems really are win-win in every technical respect.Really? The raw impedance of mid and HF drivers is mostly resistance with a small amount of inductance, so very easy. LF drivers have impedance changes at resonance, but those are generally an increase in impedance, and so pretty benign, and above resonance again tend to be largely resistive. Consequently, if anything, an amplifier connected directly to a driver will have an easier time than driving a complete passive system through a crossover.
If I could do what @BE718 has done and build some fantastic actives I would. Whenever I see him posts the measurements and pictures of the speakers I get tinges of jealously
But then there’s the amp building and crossover work.. it’s ok, if it’s more complicated than putting gypsum mud on a wall I get a bit intimidatedI can send you the cad file then all you have to do is find some local firm with a CNC machine to cut the MDF. You glue it all together and get an auto paint sprayer to finish to your taste
Simples
There’s all sorts of active and passive crossovers. In fact, one could make an active crossover behave exactly the same as a passive crossover. So you’ll need to be more specific.
Ok. I think I understand.
At the very least, I was hoping someone would have converted a passive speaker to active and measured the before/after result and also done a listening test.
ATC makes passive and active versions of the same speakers and given they believe active is better, I am surprised they still make passive versions. I can understand if that was limited to the consumer series (for folks who want to switch amps) but they do this even for the pro series. Why not make external crossovers?
In software, we have shared libraries that are well established optimal implementations of common functionality. It is expensive and stupid to reinvent the wheel. There may be different implementations for different platforms but the underlying logic is typically the same and there aren't that many platform specific implementations. I don't see this pattern in hifi speakers. I would expect to have crossovers in software that I can configure depending on speaker specifications and a standardized external module splits the signal.
I understand this is effectively what is already happening inside DSP based active speakers but it's not componentized. I find this very frustrating. As a hobbyist I want to try different speakers but they are monolithic. It's quite bizarre and needs to be addressed.
The fact that ATC and other producers haven’t gone full active; could it be lack of integrity?
To clarify: Would a doctor recommend patients to continue smoking so as not to risk losing his patients to doctors who recommend whatever the patient wishes?
Its not lack of integrity, its a reasonable commercial imperitive. At the end of the day its a business that needs to sell product. Its a poor business decision that cuts of a large segment of its market.
I dont think there is any comparison to a moral medical analogy.
But this would tell only half the story. Going active gives the designer more choice in the selection of drivers, and other aspects, so the difference should be more 'holistic' than just a straight swap for the passive crossover.At the very least, I was hoping someone would have converted a passive speaker to active and measured the before/after result and also done a listening test.
Here's a challenge: can you create a true multi-way speaker where you can switch between two completely different crossover setups (radically different frequencies, slopes) and hear no difference while playing music? With a DSP-based, driver-corrected, time aligned, linear phase three-way system, this demonstration is easily accomplished - in fact the final choice of crossover frequencies and slopes is almost arbitrary. The passive designer would be sweating over their version for months and could never achieve it: their version must always produce artefacts that are perhaps not obvious when static, but would be shown up with an instantaneous changeover.
That's exactly what I did with my B&W 801Fs.Ok. I think I understand.
