NorthSky
- Joined
- Feb 28, 2016
- Messages
- 4,998
- Likes
- 946
But but butt ...
oooooof .. I was worried! I can breathe again
The sound systems. They should all sound the same, which should be the sound of the recording - it's a very simple principle, which most people seem to want to ignore ... .It's funny that no two sound systems sound alike. ...Active or not.
It must be the rooms, or the music recordings from different masters, or the volume levels, or the listener's set of ears, or ...
That can be a most agreeable past time, you should try it Carl before dismissing out of hand it's a great way to defeat slap echo tooIn other words, it is all in your head and it is sensed where your head meets the seat of your pants. Actually, your head is stuffed into the orifice located in that vicinity.
There's sumtin serious wrong with you dude.That can be a most agreeable past time, you should try it Carl before dismissing out of hand it's a great way to defeat slap echo too
Pardon, I did not catch that...,There's sumtin serious wrong with you dude.
BAN Thomas Savage!Pardon, I did not catch that...,
Active speakers; are they remote controllable...the volume level?
No, you usually hook up a pre-amp/processor and use its volume control.
There just is not the market there to inspire the huge change in approach and huge investment it would take for these companies to establish a 'audiophile active'
Audiophiles still don't like actives!I would say that KEF, Dynaudio, and ELAC would disagree with you given all the active speakers they've launched / are launching.
There might be a market in the younger end of the scale..
I agree..I would say that's true of older audiophiles, and Dynaudio said as much, as well, when someone asked if they would be making active versions of the new Contour series; the answer was "no", because old-skool audiophiles want to mix and match components.
However, there is a new generation of audio enthusiasts with disposable incomes who are the exact opposite -- they're streaming-native and want an upgrade path from Sonos.
But I could easily conceive of allowing mixing and matching with active speakers to an even greater extent than ye traditional system - it's something I've done myself.I would say that's true of older audiophiles, and Dynaudio said as much, as well, when someone asked if they would be making active versions of the new Contour series; the answer was "no", because old-skool audiophiles want to mix and match components.
