Advice for compact Integrated Amp Dac
Xardas
Hi everybody! I'm new to the forum.
In the last few months I've read/watched a lot of reviews (but I'm still very very noob) and listened to some speakers, since I need a compact desktop system (it will be connected only to my computer, and I will use it for desktop listening, and as a general bedroom second system).
I've 99% decided for the speakers: Wharfedale Diamond 12.1 (at the beginning I thought I could spend more, but I liked their sound and tonality, so why spend more, for now).
Since on the desk I don't have much more space, I'm looking for a compact Integrated Amp with Dac, and I ask you for some info for that.
At the moment I found:
- PS Audio Sprout 100 (reviews aren't amazing, but it's probably fine for my use)
- NuPrime IDA-8 (more expensive, but I could find it used - I don't know if the sound quality would be better than the Sprout 100)
What do you think about it? Do you have more options I could consider?
I removed the NAD D3045 from the list because reviews are pretty bad, and it's really all plastic.
What I need: usb input, optical input, sub out
What I don't need: bluetooth, headphone jack, remote control
Thank you in advance!
ZolaIII
I wouldn't recommend back ported speakers for a desk nor near field all do Diamond 21.1 has a wide horizontal dispersion so it could do fine for such.
There are a lot of active studio near feald monitors and I think you would be better with such, of course front ported (all do I am not keen on such usually).
Best regards.
X
Xardas
Yes I thought about it, but the problem for me for active monitors, is that most of them have a too much analytical sound..I listened to the Genelec G3 and the Neumann KH120, they are both great, but too much revealing, I think I would be fatigued very soon..
With passive speakers it's easier to find a warmer sound and tonality.
What would you suggest?
NiagaraPete
In reality, it would be the opposite. I'd suggest going for the accurate sound and if you can afford the G 3 that would be my choice.
Timcognito
NorCal
If you're sure you want passive speakers get a small amp like this <$200 and spring for speakers and a sub
X
Xardas
Thank you, the Loxjie A30 seems exactly what I need!
Besides, as staticV3 said, it doesn't make any sense to spend 800eur for the amp and 280eur for the speakers.
This looks like a better combo overall.
Thank you everybody
