advice on setting up 2.1
OldenEars
hi all. long time reader, newly registered member. hope its ok to post this here.
Basically, i would love a link to a procedure or something to set up a ropey old 2.1 system. two kef bookshelf speakers, an old musical fidelity amp and a monitor audio active sub.
The active sub has a level and a frequency control - but no units/gradients on it. Apart from using my golden ears, is there any sciency way to try to set these dials? :)
luft262
Phoenix
1. Get a Umik-1 and download REW for free on a PC laptop.
2. Play with speaker placement, sub level, and crossover until you get a flatfish/preferred frequency response.
neRok
Australia
Yes. Get a measurement microphone such as UMIK-1 and start measuring. Then you can adjust the subs frequency knob (it's LPF) to match the speakers output as best as possible. This is to set the crossover point.
Your speakers will have a "natural" roll-off in the bottom end (a pseudo HPF). If you have no way to set a higher HPF, then you are stuck with what your speakers naturally produce. HPF can be set with certain analogue devices, or AVR's can do it digitally, or DSP on a PC or via a MiniDSP device can do this, and sometimes sub's have analogue outputs to handle this. Does your sub have RCA input and output? If so, it might do a matching HPF on the outputs, and so it would be good to wire it in between source and speaker amp. If not and you have no other means, then you get what you get with your speakers. BUT, if your speakers have ports, you might consider blocking those ports with a rolled sock or something. Blocking the port will reduce the speakers low frequency response a small amount (not a problem because the sub can do it), and it should improve the distortion characteristics of the bass that it does still put out.
Subwoofers operate in the audio zone that is extremely affected by the rooms size and the subs position within the room, and this phenomenon is known as speaker boundary interference response (SBIR). So if you can move about your sub and/or listening positioning, you might be able to get a better response than just "where ever you have it". There are techniques for finding good positions such as the "Bass Hunter Technique" from Acoustics Insider Youtube channel.
Because whilst you can get your subs controls set roughly by ear, you might get "tricked". You might adjust them in such a way that you have more bass than ever at 80Hz and think that that is great, but you might be boosting right on a room mode and/or speaker peak and making too much bass. This might sound impressive at first, but overtime you might come to realise it is too boomy or something. Similarly, if a peak at one frequency is like 10dB louder than the surrounding frequencies, it can have the effect of "shadowing" those frequencies (it makes them stand out less than they should). A measurement mic will reveal all this with no guess work.
As an example, I have a ****** subwoofer that puts out a lower SPL response from 25-45Hz, and a higher response above 50Hz. The attached gold measurement* shows these 2 shelves, but also a bunch of SBIR related issues (big peaks at 50, 70, 85, and 125, and nulls at 75 and 105). [*Ignore the red and blue ones, that was me fiddling around with DSP].
Yesterday I was trying to integrate this sub with some speakers, as stated in this thread. The speakers response drops from 60Hz, but actually I think that is also an SBIR peak, so maybe they are managing fairly flat to 50Hz (but there is a big suck-out from 100-200Hz, so maybe not). You can see the speaker only response in purple. Then I added the sub with the "frequency control" knob set at ~1/3rd, and this measurement is the pink one. You can see the sub has added 2 peaks at 50 and 77 Hz, whilst also filling up the area from 25-45Hz. I then turned the frequency up to ~2/3rds, but this added way too much bass (made those peaks too extreme).
Ideally I would have put a HPF on the speakers at ~90Hz, which would have removed their contribution to bass in the 60-80Hz range, reducing those peaks. Alas, I was limited by my available hardware, as you might be? If I had a quality sub that could play high with low passed outputs, it will probably be better for me to cross at ~150Hz, so the sub could fill in that hole from 100-200Hz.
O
OldenEars
Thanks for these replies you two. I was gonna reply that i don't want to spend more than the equipment is worth, but the mic is only $80.
Give me a little while to have a good read and look into this please.
Thanks a lot for the really fast replies :)
voodooless
Netherlands
Best you could do without spending any money is use some phone app that can show you a spectrum of what it records. then play white noise and twiddle with the controls until its halfway flat. It won’t be perfect, but ballpark enough to yield an improvement.
Astoneroad
a Cave in the desert
Mics are a hot item on the used market, so you can buy one, do your measurements, make adjustments, then sell the mic for what you bought it for. REW = $0, Mic = $0, sound & satisfaction = $pricelss. Enjoy the journey.
O
OldenEars
Honestly this is a bit more in depth than i had in mind, the system will be in a shed also used for storage :)
I do want to have a play though, so ill look at getting that mic.
O
OldenEars
I think this will be my first attempt and see if its 'good enough' which it probably will be :) ty for the suggestion.
neRok
Australia
Oh, in that case I would just start with the frequency knob at ~40% (if it's 50-150Hz adjustment, that will put it at ~90Hz), and the volume knob at low. Then turn its volume up until it sounds about right to you. If it gets a little boomy on some specific songs, try turn the freq knob down a little. If it sounds like it has a bit of a bass hole, you might try turn the freq knob up a little, and/or move the subwoofer (even if you have EQ it won't fix a null=cancellation).
O
OldenEars
will try this too. its sort of what i've been trying but its a bit imprecise i reckon ;)
Is there anything you'd suggest as a test tone or test track or anything?
