Affordable Accuracy Monitor Review
MZKM
Land O’ Lakes, FL
not the larger AA+ monitors.
May I ask why you like the Morel tweeter over the Peerless you use in the regular AAM?
I’m no speaker designer, but I’m not seeing much reason to choose the Morel which is >5x as expensive.
HiFiCompass measurements of each:
https://hificompass.com/en/speakers/measurements/morel/morel-mdt32s
https://hificompass.com/en/speakers/measurements/peerless/peerless-bc25tg15-04
They are similar in linearity.
Morel:
Peerless:
With the Peerless being a bit higher in sensitivity.
The Peerless has a more controlled off-axis
Morel:
Peerless:
And here is the distortion compared.
Morel @ ~99dB:
Peerless @ ~99dB:
Dennis Murphy
Two reasons. First, the Fs of the Vifa is 1126 Hz, while the Morel clocks in at 650 Hz. The Dayton woofer used on the AA and AA+ has to be crossed at 1900 Hz in order to avoid a serious dip in the upper midrange response and get its breakup modes suppressed sufficiently. That would put a serious strain on the Vifa, and is not considered good practice. I cross the Vifa at 3 kHz on the Pioneer mod. Second, the tweeter routing on the Dayton BR1 cabinet is 110 mm. That was done to accommodate the oversize flange on the Dayton Silky tweeter, which is a reverse engineered Morel. The flange on the Vifa is the standard 104 mm and would leave an unacceptable gap when mounted in the BR1 cabinet. I've only come across two tweets with 110 mm flanges--the Morel and the Silky. if anyone knows of another one that is less expensive than the Morel, but likely to have better quality control than the Dayton, please let me know. All this said, the Vifa is an amazing bargain. Otherwise I wouldn't consider bringing the Pioneer Mod back because it's a royal pain.
tristate0
Thanks all for the helpful discussion! Anyone have thoughts on what would be an appropriately matched center channel for a pair of (2016) Affordable Accuracy Monitors?
bigx5murf
I think Dennis used to offer a modified Pioneer center channel, to match the BS22 based AAM.
tristate0
Right. I used to.
That’s right - grateful to have gotten a pair of AAMs but missed the center channel when I had the chance! Someone on another forum suggested CMT-340, Level TWO Center Channel, or Infinity RC252. Curious whether folks have any thoughts on those or others that are available on the market.
HooStat
Calabasas, CA
A third AAM? Even if you have to buy another pair and use only 1, they are not that expensive and should match perfectly. If you have the room.
hex168
Would this work?
https://www.parts-express.com/pedocs/specs/275-200--td-2801xl-spec-sheet.pdf
skinnyq
Can anyone share what's the bare minimum you'd go for amplification for this? This is my first set of speakers and I feel really clueless. I understand these are 83 dB so really inefficient, but I'm not sure what's going to be good enough for a living room.
I've seen answers ranging from Loxjie A30 to Crown XL1502. Some people say any old AVR is going to do and some say neither of them will.
Any advice? These are also going to be hooked up to a TV with TOSLINK so I'd rather have something that has a DAC for that but I can separate them if need be.
TimW
Seattle, WA
Any old AVR should do, although they weren't all created equal. The Loxjie may be just enough if you're using these in a small room. The Crown is overkill but there's nothing wrong with that. The reality is that the little 4" woofer in this speaker can only handle so much power, especially if you're asking it to play in the bass region. I would be surprised if this woofer can handle 50 watts before self-destructing.
KEW
Skinnyq,
Tim provides good information, but I worry that you will miss out on your "audio joy" over concerns about his post.
Don't let the "50 watt limit" statement scare you too much!
Some things to help you understand where I am coming from:
The relationship between volume and Sound Pressure Level (SPL - how loud it is) is not linear. Rather it takes a doubling of wattage to gain 3dB in sound level.
1) I have listened to these speakers in a normal sized living room at room filling (but not blasting) levels without any hint of problems.
2) I'd suggest you start playing them and work the volume up to levels slightly above what you would normally consider your maximum listening level. Pay close attention to the sound (especially bass) and see if you start to hear distortions (which indicate you are pushing the limits). The idea is to establish that they can play cleanly to the level you want and, if not, establish how loud you can play them.
3) How far you are from the speakers in a major factor in how loud you are likely to want to play them. I have played them at 8' away from my listening position at the volumes I like to listen, but you may prefer louder volume levels or if you listen to music like DubStep with lots of heavy bass or music with "the Club Sound" (exaggerated bass) you could over-load the woofers!
4) If you add a subwoofer and apply a High Pass Filter (HPF) to the speakers at 80 or 100Hz, you will be unloading the most taxing signals from the speakers and the max SPL before distortion will increase for these speakers. I would recommend the Dayton Audio SUB1200 as a very good budget option but still runs around $150. Here is a good review of subs from Brent Butterworth, who is one of very few reviewers that I trust to present honest evaluations (and note that he does do CEA measurements, even though he does not make them prominent in his review - he is providing this info to the general public - an audience that is not interested in learning to interpret such measurements).
https://www.nytimes.com/wirecutter/reviews/best-budget-subwoofer/#the-competition
If the SUB1200 is beyond your budget, consider the 10" SUB1000 and, last, the Sony SACS9 Subwoofer is not a bad unit on a strict budget ($100 at BestBuy - with 14 day satisfaction guarantee or also available through Amazon).
5) If you plan to add a subwoofer, I would strongly encourage you to get the Crown amp. The reason is it will allow you to high pass filter (HPF) your mains at 80 or 100Hz (or where ever you set the sub crossover - which is actually a low pass filter for the subwoofer).
6) The Loxjie A50 looks like a nice unit, but it is a little underpowered at 18W into 8 ohms and 40W into 4 ohms. I suspect it would work for a desktop system where the speakers are only 3' away, but I worry about clipping the amp which is more often the reason for speaker failures (drivers have a hard time following the unnatural nature of a clipped signal - typical music is much easier on the drivers).
7) Just to make your life more complicated, you may want to consider the JBL 305P Mk II, which are currently on sale at $100 each. I think powered monitors are very competitive options for quality sound in this price range, and when they have a 33% discount like these do, it is a hard to beat value since you do not need to spend any money on amps.
https://www.sweetwater.com/store/de...9FW0FHgXxJI99rFxL3YaAuayEALw_wcB&gclsrc=aw.ds
https://www.audiosciencereview.com/...mkii-and-control-1-pro-monitors-review.10811/
My personal experience is these will easily beat the stock Pioneer speakers, but the version that Dennis modified to make the AA's will have some qualities to rival the JBL's. One great thing about the JBL's is they are pretty much bullet-proof as far as overpowering them - JBL tests these speakers to the Nth degree to make sure they will not blow - since they have total control over the design of both drivers and both amps (one for each tweeter and woofer), they can (and have) assign limiters to prevent destructive situations!
skinnyq
@KEW
Thank you for your post. Today I bought two second hand AVRs: Yamaha RX-V1200 and Yamaha RX-V659.
I'm going to see how they do and then decide which one to keep.
2go
I believe Dennis released limited batch of AAMs again. Just saw an update on philharmonicaudio.com $200+shipping is a very attractive price for these gems.
Dennis Murphy
Right--I have about 8 pairs of the stock 22's left . I don't intend to order any more because the mod is something of a pain, but I have enjoyed listening to them again. The Vifa tweeter is a case study in just how early diminishing returns can occur in audio.
2go
Yeah, these speakers with your mod is the best one I've heard so far. Coupled them initially with Elac Elements DAC/AMP and had gut feeling that something is wrong. Got an Amazon Link Amp and with my old Emu 0204 I was impressed how good they are. Thanks again @Dennis Murphy for that mod.
Bruce Morgen
Even though "the mod is something of a pain," would you still be willing to mod stock 22s that are shipped to you and, if so, what would that cost? "No" is perfectly understandable answer of course -- but thanks in advance for considering the question.
