This is a review and detailed measurements of the Aiyima A07 Max stereo class D amplifier. It was sent to me by the company and sells for (I think) $85 with the included power supply:
I like the little design touches and the much heavier enclosure (made out of steel?). I really appreciate the larger and staggered speaker binding terminals:
As you see, the power supply is rated at 36 volts @ 6 amps. It has no branding though so not sure about the safety marks. There are vent holes underneath and during the testing, the case stayed quite cool.
Let's see how it measures.
Aiyima A07 Max Measurements
As usual we start with our dashboard:
I had a hard time setting the output to 5 watts due to fairly large channel mismatch. I did feed each channel independent (not shown) to get them both at 5 watts and results were similar. As is, performance is very good:
Zooming in:
Noise performance is good:
Multitone shows increasing distortion at high frequencies (fairly typical):
Which winds up hurting 19+20 kHz more:
Frequency response shows the class load dependency in budget class D amplifiers but also the channel balance issue:
Crosstalk is pretty good:
Let's see how much power we have:
Pretty good amount but one channel shows that rising distortion above a few watts which we also saw in the dashboard.
There is some frequency dependency as we would expect in this class of amplification:
Amplifier is stable on power up:
The volume control is also the on/off switch. So I can't test the on/off pop the usual way as that would be at minimum level compared to other amps with separate power switch that are at full gain. So while not practical, I turned the amp on/off using the AC plug:
Aiyima has made good strides in the mechanical and outside design of the amplifier with heavier chassis with venting. The look is simpler and cleaner. And bind posts are now quite proper. Electrically, performance is similar to their other offerings which is to say it is very good. The only thing I didn't like here compared to others I have tested is channel imbalance. This is strange as I had the volume control fairly up high (as you see in the review picture) so not at the lower levels where channel imbalance usually comes up. This would cause the stereo image to shift to one side some. The sample you get may be the same, worse or better. At this price, I guess we can't expect hand picked pots but I was hoping for better.
For above reasons, the Aiyima A07 Max is not something I would buy. But your conclusion may be different.
Any
donations are much appreciated using
: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
