AIYIMA DAC-A6 Review (Stereo DAC)
Rate this DAC:
    Votes: 3 1.5%
    Votes: 41 19.9%
    Votes: 140 68.0%
  • Great (golfing panther)
    Votes: 22 10.7%
ranrt
ISRAEL
There are so many very good DACs these days at very reasonable prices.... I wonder who is buying the expensive DACs from the high-end companies that (mostly) measure worse but cost ten times or more as much...?
That's why I am happy with my Topping E30.
Dmitriy
they are bought by those who believe that the difference in sound between DACs directly depends on the cost, or those who have a lot of money and little brains, but there are currently few of them, so companies that rely on their name and not on the performance of the device, I think they will not be able to compete with brands that offer more at affordable prices
Walter
I think many are bought by people who really want good sound, but lack either the time or the technical ability to find, read, and understand sites such as this one, and instead believe what the salesman tells them.
jsrtheta
Colorado
having other ports besides USB is fine. I guess they struggled to find a breakthrough solution because they have to keep price low and add many features.
I have no use for USB, but I do for coax. At this price, I would definitely consider this.
The ESS hump is annoying, though. I thought ESS was supposed to be SOTA. Couldn't prove it by me.
nyxnyxnyx
I know right. the more ports/connection types the better.
as long as that hump isn't audible I think it's perfectly fine, it might just be one of those things we consciously remember from time to time and get annoyed by that though.
EJ3
James Island, SC
Perhaps people who don't peruse this forum? And have more money than they need.
Sal1950
The Chicago Crusher
Central Fl
I would rate it 3 stars , for the reason bellows.
1. No remote.
2. No tubes, like my Fosi audio tube P1 have.
3. Wish it had an IEC power inlet.
Why, do you believe an expensive power cord would make it sound better?
Sal1950
The Chicago Crusher
Central Fl
robertospeed
Italia
AIYIMA DAC-A6​
Tried with foobar2000 with DSDs natively with ASIO + DSTranscoder, with all these files and it works great.
FLAC 16Bit 44.1KHz
FLAC 24bit 48kHz
FLAC 24bit 88kHz
FLAC 24bit 96kHz
FLAC 24bit 176kHz
FLAC 24bit 192kHz
FLAC 32bit 192kHz
FLAC 24bit 352.8kHz
FLAC DXD 24bit 352kHz
Wav 32bit 768kHz
DSF DSD 64
DSF DSD 128
DSF DSD 256
DSF DSD 512
No pop or click noise is generated when tracks with different sample rates are randomly switched or when the power is turned on / off.
Aiyima sent me a firmware update because before it was only 24bit and not 32bit, but with the new firmware v1.03 it reaches 32bit and works fine.
AIYIMA is making some really good mini products.
Toku
Japan
Looking at the A6 of the DAC and the D03 of the amplifier, AIYIMA these days is motivated.
