AKG K371 Review (closed back headphone)
ngs428
I am looking for slightly deeper pads than stock. Ears touching the drivers after wearing for an hour. I see these pads were recommended as replacements on a few sites. I think these are the ones @oratory1990 tested and provided an eq for. Has anyone tried these? Are they deeper than stock or at least don’t compress over a few hours of listening?
Brainwavz Replacement Earpads for ATH M50X, M50BT, Steelseries Arctis, Pro Wireless & Stealth 600, HyperX Cloud, AKG, SHURE, Philips & Many More Headphones, Memory Foam Ear Pad Cushions, Black Oval
https://www.amazon.com/dp/B00MFDT894/ref=cm_sw_r_awdo_navT_a_W6EB8Y68Y6M5JSCSFJ0A?psc=1
bravomail
those might be too big. K371 pads r much smaller than Btainwavz.
GaryH
They seem to fit according to this post:
https://www.reddit.com/r/headphones/comments/g4dv5f
Just not sure of the depth or the pad not compressing after an hour or so.
And this is how they mess up the frequency response:
ngs428
Thanks! That is what I was looking for. After I wear the stock pads for an hour or so, they do compress down a bit, so that must be changing the freq response too. I will keep trying to use stock and if they get to be too bad I will try swapping. Thanks!
GaryH
Perhaps, but if more comfortable than stock? (which is of course the only good reason for using after market pads)
If you can use EQ then those frequency response changes due to the Brainwavz pads should be able to be (mostly) ameliorated with this profile by Oratory.
FrantzM
There exists a variant of this headphone but with Bluetooth, the K-371BT. Are they similar? The same as the K371 with just a BT adapter ? Has it been measured by the usual , trustworthy people (Oratorio, Crinacle, Amir, etc..? The price is most interesting, presently at $150 on Amazon
Jimbob54
Not to my knowledge.
Blumlein 88
I have a pair with the Blutooth option. I do believe they are identical. I don't have the means to measure headphones in any meaningful way. I actually got them on a sale a bit less than $150 a few weeks ago. For some reason they dropped the price for a week and then went back up.
Some report the headphone sounds the same wired, but not when BT is switched on. I've not attempted to discern the difference myself. Some report they use thinner ear pads which you'd think might change the sound. I don't know if they do or not as I've not had the regular version side by side to see.
Jimbob54
The mouth of the horse didnt know either
Garlucky
The mouth of the horse didn't know, either.
I don't get it. What didn't the horse know either?
Blumlein 88
That is rather ironic. The BT model does have a different shape on one ear cup which I took it is to make room for the BT and battery. That is why they thinned the pads. The cups are wider and they should have made a wider headband. Instead they kept the headband and thinned the pads to compensate about 3 mm each side. (I found this info after my last post in the last few minutes).
Some people recommend a few different pad swapouts. Some claim the tilted Brainwavz pads actually improve the sound over the non_BT model. Another suggestion that looks good to me are some Shure Hpaec1540 pads with super soft memory foam and a perforated alcantara material. So now we are down to headphone pad rolling. We need to get @amirm to get the BT model and measure it with stock pads and these other two. I'm sure he has plenty of time to test all phones at least three times with different pads don't you think? ;)
K371 BT with angled Brainwavz pads.
The turquoise looks pretty sweet.
proxy-image
Jimbob54
Some people recommend a few different pad swapouts. Some claim the tilted Brainwavz pads actually improve the sound over the non_BT model. Another suggestion that looks good to me are some Shure Hpaec1540 pads. So now we are down to headphone pad rolling. We need to get @amirm to get the BT model and measure it with stock pads and these other two. I'm sure he has plenty of time to test all phones at least three times with different pads don't you think? ;)
I can see his arms widening, face enraptured at the sight of the Fed Ex man bringing more boxes.
LTig
Europe
Same here. I think they sound identical to the non-BT version because @amirm's EQ settings do improve its sound. For my aging ears the sound does not change with BT enabled (without EQ in this case).
Blumlein 88
Yes, I also applied Amir's filters and the improvement was pretty noticeable. So if they are different it isn't by much and the overall trends must be the same.
pk500
The K371 BT are muddy and lack detail. Very disappointing when I tried them. I hope the wired version are better, as I'm really interested in them as a kick-around pair of closed backs.
LTig
Europe
I wouldn't count on that.
rdenney
My K371 has developed a crackling distortion in the right channel, sadly. It’s okay at low levels, but breaks up long before it becomes too loud.
Worth having repaired? I don’t know if it’s still under warranty.
Rick “sigh” Denney
LTig
Europe
Rick “sigh” Denney
First check whether a hair has managed to get loose off your head and into close contact to the driver membrane. This happened to me often with the Sennheiser headphones of the 70ies (HD 420).
