Alpine UTE-73BT Review (Head Unit)
This is a review and detailed measurements of the Alpine UTE-73BT Digital Media Receiver. It was kindly purchased new by a member and drop shipped to me. It costs US $99.99 on Amazon including free shipping.
Can't say that the UTE-73BT looks any different than a thousand other head units:
What was remarkable was how light this unit is. I don't think I have ever held a head unit that weight this little. Taking out the CD mechanism helps of course but still, it feels like it is made out of plastic even though it is not.
An Aux analog input is provided in the front as well as the USB input (I left the door open). I used both for my testing. Alas, the unit could only read one of my test files on the flash drive. It would refuse to read any other. The files were all uncompressed FLAC which it seemed to recognize but wouldn't read. Strange.
Back panel shows pre-outs which I used for testing:
Standard multi connector is used for power and speaker outs.
To test the unit, I had to power it with my bench power supply. This causes a problem in testing because we now have AC ripple that does not exist with a battery as a source. I tried to work around it as you see below but I am not happy about it. The standard solution is to power it using a battery but I can't bring one indoor. Have to see if we will be testing a lot more auto audio and if so, I will invest in proper way to power them.
Alpine UTE-73BT DAC Measurements
Per above, I put my standard 1 kHz test tone on the flash drive and had the unit play it while I measured the performance out of pre-out. I adjusted the volume one notch to get the output to be 2 volts:
This is obviously not good performance. Noise floor is quite high by desktop standards as are distortion components. You are getting about 10.5 bits of performance which is dismal for a home system. I have not tested a lot of head units to give this a precise rating. I did test a Sony RSX-G9 which scored far better with a SINAD of 89 so much better job can be done in this form factor.
Analog Input Measurement
I fed the unit analog signal through Aux input. I started with 2 volt input but that severely clipped it so I backed that down to get a dashboard view:
So no hope of improving performance by using an external DAC. Sweeping the input shows the clipping behavior:
Running a frequency response sweep shows that the input is digitized at 44.1 kHz:
There are parametric EQs in this unit so likely it digitizes the input to allow for that even for analog input. They could have done a better job though by keeping frequency response more flat.
Signal to noise ratio shows that we are missing dynamic range of 16 bit CD:
Crosstalk is fine:
Power Amplifier Measurements
I used the Aux in to test the power amplifier left and right channels:
Now you see the problem I talked about at the outset. We have a 60 Hz mains peak that dominates the measurements. This is actually the better of two bench power supplies I have. To reduce the impact of this noise, I activated a-weighting filtering in the analyzer and got this:
So we are back to 74 dB SINAD.
Frequency response is dominated by the Aux In's own bandwidth:
Signal to noise ratio is much worse now due to power supply noise but even using a-weighting, we are still coming up short:
I was surprised to see the heavy rise in distortion as frequencies got lower:
This is usually due to lack of capacitance storage in the power supply.
At 4 ohm, this thing puts out the old standard 5 watts of power:
Very sad. Switching to 8 ohm surprisingly gets you more power:
Back to 4 ohm, if you allow distortion go up higher, you do get about 10 watts:
Hard to have high expectations when paying just $100 for a head unit. Putting that aside, there is nothing here to get excited about. Performance is limited in multiple ways to around 74 dB which is quite disappointing by desktop standards. But maybe most of them are this bad, I don't know yet.
I don't have a recommendation for you either way. Need to get more data to have a good reference. Personally though I have no use for a head unit with just 5 watt of power. That is a recipe for poor performance by itself. Either get an external amp or one of the few 25 watt/channel units.
digicidal
Sin City, NV
Have to wonder if/how much better it would measure if it were a pure pre-amp configuration. It's not like those 5W are gonna be adequate for all but the quietest car interiors... and getting there either requires a very expensive car... or several times the cost of the head unit in damping/insulation (as well as all the hours tearing everything apart and putting it back together). Seems like another "solution in search of a problem" product to me.
Although to be fair even 15bits of DR in an automotive environment is plenty... at least when in motion. Just 5W however, is not plenty in any setting IMO.
3125b
Germany
They claim 4x 18W. Not a very impressive spec, yet still it fails completely :)
Makes me wonder about my even cheaper Pioneer. It gets pretty loud, so probably more than 5W/Ch.
The signal quality I think is ok for what it is. Between the high noise floor and a million other things to concentrate on, a car is just not a place for critical listening, so fidelity doesn't really matter beyond the "not completely broken" point.
Frank Dernie
Oxfordshire
IME only music with low dynamic range "works" in a car anyway. Anything with dynamics or, particularly, a big difference between quiet and loud bits needs gain riding IME and I gave up listening to the sort of music I like best in my car decades ago, the background is so loud it is pointless.
If I listen to hard rock, which i also like, it tends to encourage me to drive too fast...
I have a soft top sports car and with that I only switch on the sound system in a traffic jam - it is inaudible over about 30mph!
milosz
Chicago
No tests of the tuner section? Seems like a complete test of this unit would also measure it's tuners.
FYI you can get a very nice 12 volt gel cell - like a motorcycle battery - for very little money. It would power this unit for hours. Seems to me if you are going to test auto stereos it might be worth spending the $25 on a 9 AH battery => https://www.amazon.com/dp/B00K8V2Y8W/ref=cm_sw_em_r_mt_dp_1ZZXJHCKCEGAD2QW77SM
Robbo99999
I was gonna say, this is normally used in a car right? It's 'just' one of those common fronts you see as the main stereo unit in a car?
BeerBear
Uncompressed FLAC is a rather obscure format, that you typically have to jump through hoops to produce, so I'm not very surprised. (Assuming you meant that literally.)
Francis Vaughan
Adelaide Australia
Just eyeballing the spectra it looks suspiciously as if the entire mess is dominated by intermodulation distortion produced from the residual AC on the power supply. This device is just not intended for anything other than a pure battery to power it. Which for $100 isn't unreasonable. It would not surprise me to see the performance improve significantly when fed clean power.
rodrigaj
I had never heard of the term "head unit" before.
So this is a unit intended for an automobile.
Why is ASR testing automobile stereo systems?
(of course, you're welcome to test whatever you like - I'm just wondering.)
pjug
The power into 4 ohms is really strange. Any chance the bench supply was limiting? It needs to put out 6A 3A peak to get to the 18W into 4-ohms spec, right?
edit: brain cramping, which makes me think this not likely the problem
ck42
N. Atlanta
Oh wow..... @amirm , I think you might've opened a pandora's box on this one. Never saw a headunit review coming!!
You could double/tripple your testing load by including car audio equipment...and you'd bring in a WHOLE new audience for those reviews. You up for that? :D
m8o
What's the noise floor of everyone's car from wind, tires, engine exhaust, other vehicles, etc.? Mine is pretty high. I doubt I'd ever be affected by this thing's dismal noise floor.
P.s. while sure, ya, the ps is normally a battery and ya, the performance seen here is skewed using a bench ps ... but dont think Amir using a battery will let this perform way better. Dont forget about the alternator noise, which could be significant. Add that in to the test environment mix. If this is tested with a power source from the actual environment it is designed to operate in, I would expect worse not better performance.
sssn
Wow, has some else ever done technical measurements on car radios? :D Anyway, it's much better than I expected.
Tom C
Wisconsin, USA
I’m no expert but...
The only time the unit will be powered by the battery only is when the car is parked, and the motor’s off, right? Otherwise, the alternator will be running and charging the battery. Is the alternator output ripple free? Or does the battery supply smoothing, like a capacitor?
beagleman
Pittsburgh Pa
What was the input voltage? Car audio equipment will suffer at 12volts vs the 14.4 volts when the alternator/charging system is running
I remember reading the difference between say 12 volts and the more common 14.4 with amp output and noise, are significant.
There is some certain voltage point ( I am NOT an expert at all about this) but remember reading something over 13 volts (or so) is actually needed to get ideal performance.
