morillon
- Joined
- Apr 19, 2022
- Messages
- 1,382
- Likes
- 279
it was higher but multitones of pkanes can also carry out this kind of tests sequence...While there is certainly value in being able to present data in the same format as AP software, I think REW provides a lot of the main functionality for free, with more flexible DUT audio I/O (no need for universal ASIO), and a simpler layout. Much more accessible for hobbyists.
I also don't remember exactly, but you might end up paying considerably more than $3300 for AP Flex once you add on some of the options you need. For example, Bench Mode (the "dashboard view" most often seen at the top of these reviews) is not included with the base package.
I also prefer the REW software layout for doing multiple comparative measurements; each sweep generates its own complete set of plots, and flipping between them is clear and simple. Also MUCH easier to import past measurements and overlay in REW, which in AP I think you have to do plot by plot; you can't just import a project file over top of an existing one.
The main advantage of the AP software is its automation capabilities, i.e. being able to set up a sequence of tests and have them run automatically. There is also a Python programming interface that enables scripting more complex types of measurements than the software itself allows, such as a 3D distortion over level/freq plot.
Thread 'RME ADI-2/4 Pro SE - Auto-measured with Multitone' https://audiosciencereview.com/foru...-4-pro-se-auto-measured-with-multitone.43243/
