Amateur testing hour - any suggestions for testing without specialized equipment?
shanecoughlan
Japan
I would love to do some testing of stuff around the house. Two targets of interest right now:
Yamaha YAS 207 soundbar and sub-woofer
A pretty cheap pair of Sony NC headphones.
Any ideas on how I could get some useful data without specialized equipment?
I’m familiar with GUI or command line, Linux, MacOS or Windows, and comfortable with open source.
I have to hand some material such as a Zoom H2n recorder (pretty high fidelity stereo mics).
RayDunzl
Central Scrutinizer
Riverview FL
Room EQ Wizard is good (free) analysis software.
The H2N appears to have a USB interface for capturing sound.
That should get you started.
Don't expect accuracy without a calibrated measurement microphone, but, see what happens.
RayDunzl
Central Scrutinizer
Riverview FL
I have a Tascam handheld, and although it doesn't connect to the PC, it can record a test sweep for analysis.
It's way off...
I don't remember now (bought a UMIK-1 measurement mic) but the Tascam produced an excessively flavored (curvy) response line across its bandwidth.
https://www.amazon.co.jp/s?k=umik-1&__mk_ja_JP=カタカナ&ref=nb_sb_noss
Oooh... expensive there...
https://www.amazon.com/miniDSP-UMIK...ywords=umik-1&qid=1558807449&s=gateway&sr=8-1
I used to work for NEC America, and spent about a year at the "Abiko Plant" in Tennodai, trips in 1986, 1992, and 1998...
https://earth.google.com/web/search...UzcAomURAEYsUzcAomUTAGRZA3Dhu-UVAIaTgG9gw41HA
The local newspaper came to visit one day, at lunch they interviewed a few of us Gaijin.
The story was something about how nicely we "students" handled our hashi.
With a picture. I have it someplace if it hasn't turned to dust.
The hotel we stayed at has been turned into housing for a new Wedding Chapel...
https://earth.google.com/web/@35.85...8856295t,0r/data=ChMaEQoJL20vMDF3ajFuGAEgASgC
My favorite place to start an evening of adventures, run by an ex-Sumo, looks to be no longer in business (2014):
https://www.google.com/maps/@35.864...-dDLVs2g!2e0!5s20140301T000000!7i13312!8i6656
shanecoughlan
shanecoughlan
Japan
First tests with H4n coming soon thanks to your help :)
There is a certain charming characteristic in Japan of praising foreigners for using chopsticks well...even if most don’t. While I would hesitate to claim excessive knowledge, in my ten years here I have placed this and similar items into the bucket marked “nice things to make people feel welcome and included.” It’s either that or I have killer chopstick skills.
If you return do let me know. I’ll send you some recommendations.
DonH56
Monument, CO
REW: https://www.roomeqwizard.com/
Calibrated UMIK-1: http://cross-spectrum.com/measurement/calibrated_umik.html
I found the UMIK-1 to have less noise and wider dynamic range than the Dayton variants FWIWFM.
CSL also sells the Galaxy CM-140 SPL meter, a decent SPL meter for ~$100. Not the cheapest but as good or better than most inexpensive meters. Wish I had kept my old wideband SPL meters but REW + CSL UMIK-1 + CSL Galaxy 140 combined is much cheaper than a high-end wideband SPL meter. My CSL's corrected response essentially overlies my Earthworks M30's curve. The UMIK-1 cannot match the noise floor and dynamic range of the M30 but for about 1/10th the cost is more than adequate for normal audio use.
If you want to measure components, then a pro ADC and some of the free (or paid) software around the 'net will be a great start. For things like DACs and really high-performance components it may be hard to match an Audio Precision test set, however. Last time I looked at used AP or similar (HP/Agilent/Keysight) audio testers used ones within a couple generations of the latest were still around $10k, too rich for me. I'll just read @amirm's posts instead.
