AMP + DAC for HifiMan Sundara
Ole_S
Hi Guys,
I have just bought a couple of WifiMan Sundara.
Now I just need an AMP + DAC.
I an considering:
Topping DX7 Pro = 359 USD (1,5 years old)
Topping DX3 Pro+ = 214 USD (new)
Topping E30 + L30 = 354 USD (new) + bluetooth device is must be included to the system
Topping E50 + D50 = 427 USD (new) + bluetooth device is must be included to the system
What do you think?
If you have any better setups, please do not hesitate to add. :)
Best regards,
Ole_S
Dunring
Florida
I've had all of those, the Topping e30ii/l30ii is the best value, but the e50/l50 is amazing too for the quiet noise floor. Tons of power but also really great in low gain for IEMs.
O
Ole_S
Thank you for replying.
Then I need a separat amp/DAC for bluetooth playing.
Bluetooth is used for movie watching from the tv.
O
Ole_S
Other setups could be:
  • Chord Mojo 2: portable and very well playing dac/amp
  • Ifi Audio ZEN Signature Set 6XX
Misguided
I currently use a SMSL H0100 amp and plan to buy a SMSL D0100 DAC which has Bluetooth. The SMSL C200 is also a good option and I believe there are quite a few others.
O
Ole_S
Thanks,
I will look at these devices.
Tonton_ZEeD
France
I have run my Sundara on 3 different amps:
Topping DX3: for the price it's great, tone control and decent power.
Topping d10s + Ifi Zen Can: another good amp. SE is good, power is fine, a little smoother in the high and the magical bass boost, great for my taste. Balanced = more power, a touch of authority
Topping D30pro/A30pro stack: only balanced no magical button but more authority and satisfaction. Maybe a little bit of EQ for my listening pleasure.
Go for an dac/amp with features you don't need lot of power.
Fiio K7 could be a good option, Se and balanced output, plenty of input, usb coax toslink and BT for less than 230$
O
Ole_S
Hi,
Thanks for replying.
You say that Sundara does not need not of power?
I have heard that these Planars require quite a lot of juice to run optimally.
Tonton_ZEeD
France
Hi,
They don't run on a phone, but on my lil DAP 190 mW / 32 ohms, it's OK
Modern desktop amp have enough power, set a budget, consider features and practicality, and enjoy. there is plenty of good choices with topping smsl fiio etc etc etc
DX3+ or Fiio k7, for the money they are both great.
JSmith
Algol Perseus
JSmith
O
Ole_S
JSmith
Hi,
Thank you for input.
Since I am total newbie to this HeadFi-World I am not totally sure that you would like to show? :)
Thank you.
O
Ole_S
JSmith
I can see that EQ of the headphones is a very good idea.
Can you please recommend software for both IOS + Android?
Thank you.
JSmith
Algol Perseus
There is much listed in this thread by @Doodski;
JSmith
O
Ole_S
Sukie
Thank you.
Are you connecting your phone/tablet directly to the DAC? If so, what is your audio source, i.e. what streaming service are you using?
O
Ole_S
Hi Sukie,
Thank you for asking.
Yes, I am connecting my Android phone and Macbook directly to the DAC.
When using my Android phone, I am using USB AUDIO PLAYER PRO (software).
I am mostly using Qobuz or Tidal.
Sukie
USB Audio Player Pro has the ToneBoosters Parametric Equaliser paid add on. I seem to recall that it's pretty good. You can then add in Amir's settings, or any of your choice. I use Oratory 1990s Harman settings.
One thing with the ToneBoosters PEQ, there isn't a "peak" filter type, you use "Analog Bell" instead. This one confused me!
O
Ole_S
Thanks a lot.
That was very helpful :)
O
Ole_S
What about the build-in EQ in USB Audio Player Pro?
Is not that good enough?
Sukie
I think the built in one is the ToneBoosters one. You have to pay a small amount to use it. I haven't used USBAPP for a while though.
