AMP + DAC for HifiMan Sundara
O
Ole_S
I think the built in one is the ToneBoosters one. You have to pay a small amount to use it. I haven't used USBAPP for a while though.
EQ = Free
Parametric EQ = 39€
O
Ole_S
I just need an AMP/dac for transportable music listening.
No bluetooth needed here, since I have decided to buy a desktop dac with building bluetooth.
This will give me more options when picking the new transportable amp/dac.
What do you think? :)
O
Ole_S
I am just curious:
What about iFi Audio Zen + HifiMan Sundara.
Is it a bad match? Or maybe there is just better setup for Sundara? :)
JSmith
Algol Perseus
Both these do include BT, but are priced ok and measure well... although the Topping has more power available;
JSmith
O
Ole_S
JSmith
Thank again :)
Included bluetooth is totally okay - just a nice extra feature.
Would you recommend Topping G5 for Sundara?
G5 is quite big for transportable use. Bigger than BTR7.
I wonder if G5 is too big for my pockets.
Is G5 much better than BTR7, then of course I can consider buying this one.
Otherwise, BRTR 5 or BTR7 will be more suitable for me.
Theodore8
Geneva, Switzerland
In my experience, DX3 Pro+, while a great piece of equipment, has too low power output. I would shell out an extra $100 to ensure enough power.
O
Ole_S
Thanks for input.
I need Bluetooth in my desktop amp/DAC for TV/movie.
Therefore, L50 + E50 is not an option here :-(
How to solve this?
O
Ole_S
Is it possible to add BTR7 to the Topping E50, and make this setup bluetooth for TV/movie?
Jimbob54
EQ = Free
Parametric EQ = 39€
39E sounds expensive for the EQ plugin- I thought it was more like £5-9 when I bought it years ago. The Morphit plugin is only £4 (I know thats not the same thing but remember EQ plugin being similar price to it.
Jimbob54
$ does not equal power necessarily- what device were you thinking of?
O
Ole_S
Morphit plugin is 39€ :-(
At least in Europa.
Jimbob54
At least in Europa.
Not the same- you buy the add on within UAPP itself - thats the full Windows suite. Get a trial of UAPP and see what teh PEQ add on price is
O
Ole_S
I do not think you are gonna buy amp/dac just for ONE pair of headphones?
Hopefully the amp/dac kan suit more than this one pair. ;):cool:
O
Ole_S
I have already bought UAPP.
When I try to buy Morphit within the APP, the price is still 39€. :-(
Jimbob54
But you are asking for a dac/amp for a specific pair of headphones in the thread? For info the DX3 pro + will put over 1 watt into the Sundara in high gain. Over 200mw into a 300 ohm pair like the Senn HD600. Its potent.
O
Ole_S
For that matter, of course you are right.
I am pretty sure to pick the Topping E50 + L50.
I just need a solution how to connect bluetooth to this setup, playing TV/movies.
Theodore8
Geneva, Switzerland
Not sure what setup you have, but an Rpi4 running Moode should be able to pickup a BT signal and output it to the E50 via USB. Total cost about $70 with case, power, and USB cable.
Or maybe I have not understood your issue…?
Theodore8
Geneva, Switzerland
Sundara is 35 Ohm, not 300 Ohm like HD600… it’s a whole different challenge for the DX3…
O
Ole_S
Desktop-setup:
Topping L50 + E50 (this setup does not included Bluetooth)
I need Bluetooth for TV/movie.
Therefore, I am asking if BTR7 can be connected to my Topping E50?
There is no need buying Rpi4, if I can connect BTR7 to my E50.
TV signal (bluetooth) --> BRT7 connected to the L50/E50 --> HifiMan Sundara.
But is that doable?
Jimbob54
Im going to humbly suggest you are doing something wrong there- or need to speak to the Devs/ Google
Ive just clicked "purchase" for both plugins in UAPP on a different phone/ google account
