Amplifier recommendations for vintage KEF 105.1
fordiebianco
British Isles
Dear All,
I am the happy owner of a pair of recently restored (crossover, tweeters) KEF 105 Mark Ones. They are standing in a medium sized room (ca 16square meters), away from the walls, about 3 meters away from my listening position. I mainly listen to Jazz, symphonic and chamber music, and quite a bit of what you would have called in the eighties 'New Jazz', but not particularly loud, because I quite like my neighbours.
I have a few chip amps amps (Allo Volt D+, Aiyima A07, etc), a few 'classic' but underpowered vintage receivers from the 70s (which I keep for the looks only), and a typical 80s 'big iron' Denon Power Amp (the SM-80: 100 w into 8 ohm per channel).
To remind you of the specs of the KEFs:
  • Size: 965 x 415 x 455 mm (38 x 16.3 x 17.9 inches)
  • Input Impedance: 8 ohms
  • Rated maximum power: 200W programme
  • Amplifier Requirements: 40-200 watts per channel into 8 ohms
  • Frequency response: 38-22,000Hz +/-2dB at 2m on measuring axis
  • Sensitivity: 86dB at 1m for 1W, anechoic conditions
  • Crossover Frequencies: 400, 2500Hz
In your learned opinion, what is a reasonable amplifier's power output for these speakers? Am I ok with my 20-50w classic receivers (even though they might not have the THD of the Volt D+) or do they need something beefier, even for my moderate listening levels?
Many thanks for helping,
FB
DanielT
Sweden - Слава Україні
You have Sensitivity: 86dB at 1m for 1W ,.
It's probably not so stupid to have enough power so the amplifier can handle transistent peaks. I had probably invested in hm at least 250 W. Plus an amplifier that really has those fat bass modules in iron grip. BUT it depends on the type of music you play. If you play music that is compressed, it places less demands on the amplifier.
The red tops are the reason, among other things, why it is good to have much effect. Even at normal listening volume, it requires the amplifier to handle them in a good way. Otherwise, push the amplifier into clipping. An amplifier that clips sounds really bad.
Here is a video from a DIY Vintage fair I was at. The video does not do justice to how it sounded IRL but it does give an indication of what a capable rig that is not driven into clipping, or begins to show distortion can perform. It was all seriously completely incomparable.:)
Please note I am not an expert. Recommendations are more of a guess. A good rule of thumb now that pure many watts can be obtained for relatively little money, invest in getting space, headroom, lots off W. Then after that you should think about fixing even more headroom / effect.
You who like vintage. here some vintage porn. KEF is included, Björn's DIY :)
fordiebianco
fordiebianco
British Isles
Hi @DanielT
many thanks for your kind help and explanation. Definitely not listening to very compressed music. I might have to rethink my approach to amplifiers and get two beefy mono stages.
...and thank you for the cool pics. Looked like an amazing day out.
FB
DanielT
At least I would have done that if I were in your place. Too much or too little power 250 W I do not know but as I said better too much than too little.:)
Hope someone else gives you tips and advice. It based on your condition had been interesting to read about. I'm not that experienced so I will follow your thread with interest.
I think it's fun and interesting with vintage. Also sound and radio history. Tips on opportunity are available visit a radio museum.Nearby where you live.:)
I think you can, for example, in the main system can have modern stuff. Sharp Hypex based amplifier for example. Then in the secondary system have vintage. In the bedroom, hobby room, garage for example. Then the vintage looks nice (of course the taste is like the butt, divided, but still).
You have nice speakers, by the way.:D
Willem
It is only a small room, so I would think your 2x100 watt Denon will do the job. If you want to spend money, I would go for a big Hypex stereo model. Monoblocks are unecessary in a room like this.
DanielT
Aha, about 16square meters), away..Sorry I missed that.:)
Is there no calculator regarding at least getting a clue on the appropriate effect?
I know, because I mentioned it earlier, that it depends on a lot of factors but still. It would have been fun to test such a calculator.:)
Edit
Fordiebianco you will not like this considering your new passive filters, but I throw up the idea anyway. Powerful class d amplifier that drives the bass modules, another amplifier that drives the top speakers.:)
Then you need to split the signal from your source into two different amplifiers and either run an active analog filter or set the filter in the digital world.
EQ and bass modules / subwoofers are a happy marriage. In case you want to freshen up and get a smoother frequency curve in the lowest frequency registers.:)
This one for your bass modules should fix it well. I think.Good price on it too.
The Behringer A800 does what pro amps try to do: provide solid, middle-of-the-road distortion and noise with tons of power in quiet and light package for little money. The design is stable and better than the A500. As such, I can recommend the A800 as an everyday amplifier.
Are these your model of Kef speakers?
fordiebianco
fordiebianco
British Isles
Hi Daniel,
not quite. Mine are (not quite as well preserved) like these:
fordiebianco
fordiebianco
British Isles
Many thanks @Willem . I will get the Denon out of storage and schlepp it downstairs and give it another whirl. In the meantime I have ordered one of the TPA3255-A based chipamps with alleged 2x150W into 8 Ohm. See how that pans out.
