Analog Signal Processor vs. Oscilloscope
Madjalapeno
NH, USA
I'm in the process of building some Linkwitz LX521 speakers, which require a signal processor for cross over purposes. I decided to go with an Analog version for now.
As a final sanity check I thought I would look at the signals with a 2 channel oscilloscope, and wanted to share as I thought it was interesting.
I have one channel hooked up to the output of a Topping E30, and the other to the output of the ASP and am playing random music via Roon.
Woofer
Lower Mid-range
Upper Mid-range
Tweeter
I also set the sampling rate to be faster, as the tweeter doesn't show much
Woofer - Fast
Lower Mid - Fast
Upper Mid - Fast
Tweeter - Fast
Madjalapeno
Madjalapeno
NH, USA
Repeated with pink noise
pink noise - woofer
pink noise - lower mid
pink noise - upper mid
pink noise - tweeter
mansr
Hampshire
Will see if I can find a signal generator - it's not likely to damage anything is it?
Use a DAC. Whatever you used to create the pink noise can probably do a square wave too. No, it won't break anything.
The signal generator will likely not be able to drive a speaker by itself. You need to feed it to an amplifier. And yes, be careful with square wave, white noise, etc. as they can damage your speaker and/or your ears at high levels.
mansr
Hampshire
I had the impression the OP was measuring a crossover filter without speakers connected. If speakers are connected, too much HF energy can of course do damage.
Madjalapeno
Madjalapeno
NH, USA
It's not going anywhere near my amps or speakers. This is purely a bench top exercise. Thought it was interesting to see how a cross-over/ASP works.
Madjalapeno
Madjalapeno
NH, USA
Playing via Audacity this time for slightly better control.
Square wave at 440Hz. Yellow is output from Topping E30, Purple is output from ASP.
Woofer
Lower Mid
Upper Mid
Tweeter
Madjalapeno
Madjalapeno
NH, USA
some more audacity playing
Pluck (midi pitch 60, fade out abrupt)
Woofer
LM
UM
T
