xirtam2005
- Joined
- Jan 1, 2022
- Messages
- 144
- Likes
- 40
Thanks for all your helpful comments. They have been eye (and ear) opening, especially the frequency response curve, which made me sick to see.Reading through your post, I find that I agree 100% (except for the no sin part so let's call it 98%)
I'll also add that the 12V trigger on the STR is handy
The only issue I had with the STR was having to use the beta software because of an issue due to using my amps on a low gain setting, otherwise the usability was pretty flawless.
I'll admit I have a bit of buyer's remorse, since the speakers I actually auditioned had a much flatter FR, but with my current responsibilities, do not have the bandwidth to change speakers. Especially since it would probably be much more expensive to have something that sounds similar enough to the Personas (fast, accurate, clear, articulate, good imaging) without the jazzed/sauced > 5 khz treble, not to mention the effort to market and sell the Personas to a genuine buyer.
I realize I really like the Paradigm Persona speakers and the way they perform when most of the information in the music is < 5 Khz. Guitar solos, stringed quartets, most classical, "unplugged" hi res rock albums, well recorded classic rock are simply amazing. Even classical sounds good - don't mind the air in the upper harmonics.
However for modern/electronic pop, etc where synthesizers or other electronic instruments are used with recording information and/or sonic effects/intentional distortion above 5 Khz, yes, it sounds bright and fatiguing and relatively unbalanced.
All this time I thought either most modern material was bad recordings and/or was suffering from Oppo "ESS Sabre glare". I was wrong.
I'm really hoping ARC in the Anthem STR Preamp will do the trick. I truly don’t have the bandwith, time and energy to change out the speakers. That could hurt my marriage and is not worth it.
