Any point in buying high spec dac to input into AVR?
Mattknz
New Zealand
I'm currently using a pi with a Boss 1.2 hat dac and sending the output into a Denon avrx3300w in order to use Audyssey room correction.
Is there any gain to be had by using a high sinad dac before the avr when the avr is going to perform analogue to digital conversion and then output a signal with a sinad of probably 80ish db?
GalZohar
As far as I know your understanding is correct and there is no point in a super high quality DAC as that would just get converted back to digital by the AVR. Of course, a poor DAC may still make the sound worse. Best to just use digital inputs unless you are using pure direct, which disables room correction or bass management. Rven if you don't normally use those, the benefits of a high quality external dac are quite questionable.
Steve Dallas
A Whole Other Country
If you are using room correction, any analog input will go through AD conversion before the DSP, then go through DA conversion. There is no benefit to DAC -> ADC -> DSP -> DAC, when you can inject digital into the AVR and skip the DAC -> ADC stages.
Looks like there are several hats out available to output Toslink digital.
euge_lee
Cool, confirmed my thoughts a nd saved me some money!
Thanks all.
Technically... if you use your own DAC, and your AVR has "multi-channel line in"... you can use those inputs and bypass your AVR or Pre/Pro onboard DACs.
antcollinet
UK/Cheshire
But not if you want to use the AVR's DSP room correction
euge_lee
So you missed in the OP:
Seems that I did. Well yeah then the external DAC seems pointless. Unless he wants to unfold some MQA or upsample in the DAC to DSD512 then output to analog to have that then re-digitized by the AVR. LOL.
Mnyb
Sweden, Västerås
Yes a Pi-hat with digital output is the way to go :) imho it's good enough for any pre-pro or AVR .
hmt
No.
phoenixdogfan
Nashville
//////I'm currently using a pi with a Boss 1.2 hat dac and sending the output into a Denon avrx3300w in order to use Audyssey room correction.
Of course one day you may decide to ditch the Denon for something with a Sinad that matches your DAC, and you can use Camilla Dsp on the Pi.
