Ascend Sierra Luna Duo Center/Main Speaker Review
wwenze
BTW, how do members feel when their stuff tests badly?
Hopefully they can still enjoy the stuff or return them somehow?
I found myself stuck in a situation where the response that I think sounds best has a +6dB low shelf filter at around 750Hz, a slight but slow bass rolloff below 100Hz, reduced treble above 10kHz, and somehow the middle treble between 1kHz and 10kHz doesn't matter. In-room measurement, not anechoic response of the speaker. But of course the appropriate speaker + the table are needed to get this response.
And I'm still using this response instead of the auto-EQ by REW.
YSC
it's always a shame where manufacturer managed to get exotic looks and materials for such good looking yet expensive speakers to perform that badly... I can accept is kind of Asus ROG or similar computer gaming accessories as they might aim for look or amplify certain gaming need frequencies or so, but hifi speaker this broken is totally unacceptable...
hardisj
Reviewer
North Alabama
I see their website specifically mentions “quasi-anechoic” as well as a note to ignore response below 250Hz. This tells me that they’re doing the typical measurement method of gating and merging. If so, their measurement method simply doesn’t have the resolution to show narrow midrange resonances. A window of at least 20Hz accuracy would be needed to show these kind of resonances because the Q is so high. Windowing just glosses over these things. It’s the downside to the often used quasi-anechoic method. These can be done pretty easily in a large parking lot, street or driveway with no obstructions, though.
http://www.ascendacoustics.com/pages/products/speakers/duo/duomeas.html
MZKM
Land O’ Lakes, FL
That's good.
Also part of what he said:
One thing I found interesting is that in Amir’s 96 dB distortion measurement, which applies a 60Hz high pass filter, thus rolling off bass below 60Hz, the fundamental – which is the actual frequency response, looks much more similar to ours with less port resonance. I have never used a near field scanning system for loudspeaker measurement, this is a new technology, we use tried and true MLSSA systems, so there may be differences as to how port output is summed in the near field, resolution differences, or the NFS system might be sending a lot of low frequency information to the speaker at a high amplitude – thus exciting port resonances to a higher degree (this could explain the frequency response differences I noted in the distortion)
http://forum.ascendacoustics.com/showthread.php?6574-Which-center-Luna-S2-or-Horizon/page6
levimax
San Diego
Out of the almost 100 speakers tested do any of them with a ribbon tweeter measure well? Seems like a trend.
hardisj
Reviewer
North Alabama
hardisj
Reviewer
North Alabama
Looks good!.... usually it is not the technology but rather the implementation that makes the difference... can you send a speaker to Amir to test?
The speakers aren’t mine. Just ones I tested. Sorry, my post isn’t clear.
And no need to send them to Amir anyway. The tests are solid. ;)
617
Somerville, MA
He doesn't indicate the key thing which is where the speaker was measured and how he handled low frequency response/reflections. The Mic and software are not important bits. But yes, it does seem like old software and such given the look of the graphs.
Unless anechoic chamber was used (highly doubtful), the accuracy is far, far worse than Klippel NFS.
Quasi anechoic measurement could explain the poor resolution in mid bass, which would gloss over the port resonances.
YSC
Does the Adam s2v count as ribbon? If so that measure remarkably
617
Somerville, MA
A two way with ribbons is very, very hard to pull off.
Gyroscopics
My self-assembled version of Dennis Murphy's AA+ has much better FR than this and costs 1/8 as much.
Edit: 1/8 the cost per pair
xykreinov
Clearly, you're paying for the least deviation from the well-researched Batman target curve
ROOSKIE
Minneapolis
Yah Solid indeed. Some of the best around for sure.
Digging your reviews and just saw the Revel. Sick( meaning excellent)
Dennis Murphy
No--it uses a garden variety AMT (aka Heil transformer). A good AMT will generally have superior distortion properties at the bottom end of its operating range (hence its frequent appearance in 2-ways), but frequently won't measure as well at the top end as a good ribbon. To add to the confusion, the unit that Rick Craig uses in his Purezza is neither an AMT nor a ribbon, but some kind of combination I don't quite understand.
Maiky76
French, living in China
Hi,
Here is the EQ, really challenging to say the least.
Score no EQ: 1.41 poor! 4.26 with sub
Spinorama no EQ
Directivity
horizontal is Ok but vertical is very poor, must stay right at tweeter height
too much energy above 6k compared to the rest of the spectrum.
EQ design:
large deviation from the flat seed showing issues with directivity.
Very uneven frequency response. Very difficult to EQ.
Score with EQ: 4.75 still bad for the price / 7.21 with sub
Code:
Ascend Sierra Luna Duo APO EQ Score 96000Hz
November042020-130445
Preamp: -2.6 dB
Filter 1: ON PK Fc 60 Hz Gain 3 dB Q 0.86
Filter 2: ON PK Fc 162 Hz Gain -4.15 dB Q 1.3
Filter 3: ON PK Fc 555 Hz Gain 2.51 dB Q 2.5
Filter 4: ON PK Fc 602 Hz Gain -4.5 dB Q 18.2
Filter 5: ON PK Fc 1655 Hz Gain -6.46 dB Q 3.93
Filter 6: ON PK Fc 2916 Hz Gain -1.83 dB Q 6.59
Filter 7: ON PK Fc 5945 Hz Gain -4.23 dB Q 1.5
Filter 8: ON PK Fc 10910 Hz Gain -4.92 dB Q 0.75
Filter 9: ON HSC Fc 832 Hz Gain 2.9 dB Q 0.88
Filter 10: ON PK Fc 876.5 Hz Gain -2.84 dB Q 5
EQed spinorama
Zoom PIR-LW-ON
Regression Tonal
very large improvements
Like for its little brother, many, many speakers, at much lower prices, measure much better...
  • Ascend Sierra Luna Duo APO EQ Score 96000Hz.txt
617
Somerville, MA
https://audioxpress.com/article/test-bench-bozhen-new-audio-lab-cq66-ribbon-tweeter
Surely just a big ass ribbon?
