- Joined
- Mar 5, 2020
- Messages
- 98
- Likes
- 180
Thanks Amir!
I am not a fan of ribbons unless they are in a 3 way and limited to playing lower down.
It seems amazing that similar looking speakers to these can measure so much better. At least it looks good
With a front port and hanging brackets, I am wondering if the goal for these is rear surround speakers.
Here is the info from their website
"The Luna’s versatility is unmatched, crossed at 80Hz and used with a sub, they make terrific main's sounding nearly identical to our Sierra-2. The Luna’s are the perfect surround speaker with any of our ribbon speakers as fronts, or for someone seeking the ultimate desktop monitor. Using the integrated mounting hardware, the Luna’s become the perfect on-wall speaker. "
"crossed at 80Hz and used with a sub, they make terrific main's sounding nearly identical to our Sierra-2.
You would need to use an AVR's dsp and also need a ton of power?
"The Luna’s are the perfect surround speaker with any of our ribbon speakers as fronts"
This seems like the most likely fit. Would a mid range AVR have enough power for these to handle surround channel duty?
"Or for someone seeking the ultimate desktop monitor"
You would need a subwoofer and good DSP just to get close.
It's certainly not easy to design a passive speaker of this size that will do well with the ASR test methods.
- There isn't room in the cabinet to employ a very complex crossover, which usually limits how linear the response can be.
- Any of the available enclosure options are a challenge.
- A port has to have a relatively small cross sectional area in order to have a length that will reasonably fit in such a small cabinet, which will lead to high velocities and the associated turbulence/resonance if trying to make any substantial bass.
- A sealed enclosure this small will not allow much bass extension.
- A passive radiator will need to be on a side or rear of the cabinet, which limits placement/mounting options. It can also be difficult to avoid physical interference between the woofer and passive radiator(s). There just isn't a lot of room.
- The response can be linearized and individual driver responses can be tailored with outcomes that would be difficult to achieve passively.
- Deep bass can be filtered out aggressively
- Reduced port turbulence and woofer distortion
- Increased SPL capability
- A sealed design can be tailored with some bass boost combined with a sharp cutoff.
The typical use cases for a speaker of this size are as outlined by Ascend (high-passed with a sub filling the bottom, or nearfield low SPL duty). In those use cases the port and distortion issues will not be nearly as large an issue as indicated by the ASR measurements. The ASR measurements are certainly useful to indicate what a speaker can and can't do, but it is important to keep in mind that the weaknesses identified may not be applicable to your use case. Small speakers can provide a good experience when used within their limitations.
