This is a review and detailed measurements of the Audeze LCD-XC (late 2021 edition). It was sent to me by the company and costs either US $1,299 or $1,799 depending on accessories.
The LCD-XC feels quite sturdy and solidly built. Alas, it is also the heavies headphone I have measured:
The cups are quite comfortable for me and other than feeling some pressure against the sides of my head, I didn't have any problem wearing it for a while.
Note: The measurements you are about to see are made using a standardized Gras 45C. Headphone measurements by definition are approximate and variable so don't be surprised if other measurements even if performed with the same fixtures as mine, differ in end results. Protocols vary such as headband pressure and averaging (which I don't do). As you will see, I confirm the approximate accuracy of the measurements using Equalization and listening tests. Ultimately headphone measurements are less exact than speakers mostly in bass and above a few kilohertz so keep that in mind as you read these tests. If you think you have an exact idea of a headphone performance, you are likely wrong!
The LCD-X was easy to measure, fitting on my fixture with little adjustment.
Audeze LCD-XC Measurements
Let's start with our usual frequency response measurements:
I was pleasantly surprised to see good compliance with our target curve for a good part of it. Headphone fixture reliability is low in high frequencies but it is possible that the sound is a bit bright due to peaks above 10 kHz for those of you blessed to still have your full hearing range.
Relative frequency response (to our target) gives an easier view of what needs to be corrected using filters for optimal sound:
As with some of the other Audeze headphones I have measured, the LCD-X demonstrates stunningly low levels of distortion:
Even at 114 dBSPL (green) we have little to no distortion! At reference measurement of 94 dBSPL (blue), distortion reduces to some -84 dB which is audio electronic domain, not a mechanical transducer! Considering that there is some measurement noise in there as well, the actual distortion may be even lower. If some of that weight has gone toward making less distortion, I say keep on adding weight!
In absolute terms, distortion again proves to be incredibly low:
I suggest anyone performing audibility of distortion tests to use headphones like the LCD-XC.
Group delay is also very clean showing absence of secondary resonances that combine to create phase non-linearity:
Impedance is low and flat as is typical of this class:
I again suspect some of that weight has gone toward making this headphone quite sensitive:
Audeze LCD-XC Listening Tests and Equalization
Out of box response was fine. Not annoying but a bit ordinary. I first turned on the LCD-XC correction in my Roon player and it did improve the sound fair bit. I then developed my own:
The response is rather complex and my filters rather simple so a more optimal one may be developed using mathematical means. Comparing mine to the built-in profile, I found that they are two flavors of excellent sound. I have a slight preference for mine though.
Post EQ, spatial qualities were excellent with instruments taking up their own spot in 3-D space outside of each ear to the left and right with some depth. On tracks that have such qualities, it is quite a nice experience.
Bass performance with EQ was superb when combined with efficiency of these headphones. With modest power driving them you can still get reference quality bass down to 20 Hz. Turn up the volume some and dynamics become incredible.
Audeze is one of only two companies providing headphones to me for testing. For this alone, they deserve many kudos (as well as waiting some 6 months for me to test this headphone
). More importantly, I like how they have gotten closer to our preference curve and with it, provided a nice out of box experience. Given the ultra low distortion, you can easily make corrections to the response to create the sound you want. Efficiency is also high making it easier to drive than many other headphones.
I am going to recommend the Audeze LCD-XC. With EQ, I will up my recommendation to highest level!
Any
donations are much appreciated using
: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
