LCD-XC 2021 EQ Revision 12-03-22
This EQ Revision most religiously respects the Harman Target Curve 2018 from the frequencies 900Hz - 8000Hz. I did not just follow the Curve blindly, it was just after a lot of experimentation and trial and error that I discovered that there is just 'SOMETHING' about this Harman thing that is just spot on beautiful. Like chicken skin on songs I've heard 100s of times before. Amazing!
Sub bass is a horizontal line all of the way down to 20Hz for true flat sub bass extension for that extra bottomless slam available in songs that utilize these frequencies. 80Hz is emphasized as usual in my EQs to bring out the punch in kick drums. 300Hz and 740Hz are emphasized to bring out the top end of kick drums and the meatier parts of snare drums respectively.
I know that there are a lot of filters and I've been told that before. I have never heard any sound degradation in the year that I've been EQing with Equalizer APO and with the attached .txt file all you have to do is import it, no typing in values. Yes, I find it necessary to use a lot of filters, nuff said about that.
Preamp: -19.58 dB
Filter 1: ON PK Fc 20 Hz Gain 4.5 dB Q 1.3
Filter 2: ON PK Fc 27 Hz Gain 0.4 dB Q 6
Filter 3: ON LSC Fc 39.5 Hz Gain 6.3 dB Q 0.7
Filter 4: ON LSC Fc 40.2 Hz Gain 1.13 dB Q 4
Filter 5: ON PK Fc 80 Hz Gain 7.2 dB Q 1.79
Filter 6: ON LSC Fc 130 Hz Gain 7.42 dB Q 0.7
Filter 7: ON PK Fc 197 Hz Gain -8.7 dB Q 1.4
Filter 8: ON PK Fc 250 Hz Gain 6.97 dB Q 0.6
Filter 9: ON PK Fc 590 Hz Gain 2.45 dB Q 3.3
Filter 10: ON PK Fc 740 Hz Gain -1.27 dB Q 2.5
Filter 11: ON PK Fc 1015 Hz Gain -2.45 dB Q 1.5
Filter 12: ON PK Fc 1015 Hz Gain 2.9 dB Q 2.9
Filter 13: ON PK Fc 1300 Hz Gain 0.33 dB Q 3.2
Filter 14: ON PK Fc 1675 Hz Gain 1.55 dB Q 4.5
Filter 15: ON PK Fc 1800 Hz Gain -4.35 dB Q 0.9
Filter 16: ON PK Fc 2000 Hz Gain 0.3 dB Q 5
Filter 17: ON PK Fc 2350 Hz Gain 1.95 dB Q 4
Filter 18: ON PK Fc 2700 Hz Gain -0.47 dB Q 5
Filter 19: ON PK Fc 3050 Hz Gain 0.5 dB Q 4
Filter 20: ON PK Fc 3600 Hz Gain -0.35 dB Q 4
Filter 21: ON PK Fc 4000 Hz Gain 0.38 dB Q 4.5
Filter 22: ON PK Fc 4150 Hz Gain 4.2 dB Q 2.1
Filter 23: ON PK Fc 4300 Hz Gain 0.91 dB Q 2
Filter 24: ON PK Fc 5750 Hz Gain -3.82 dB Q 3.7
Filter 25: ON PK Fc 6500 Hz Gain 0.3 dB Q 2
Filter 26: ON PK Fc 7300 Hz Gain 2.1 dB Q 3
Filter 27: ON PK Fc 9000 Hz Gain -8.6 dB Q 6
Filter 28: ON HSC Fc 10000 Hz Gain 2.29 dB Q 1
Filter 29: ON HSC Fc 13000 Hz Gain 1 dB Q 2.7
Filter 30: ON PK Fc 19000 Hz Gain 1.47 dB Q 0.6
Filter 31: ON PK Fc 4900 Hz Gain -0.2 dB Q 4
If you want less or more bass, simply adjust the gain of filter 5 and then change the Pre-amp level back to -0.1.
I have a new respect for parts of the Harman Target Curve now. Make sure you have a powerful headphone amp and try it out for yourself, it will sound great on anything you play!
Blessings,
Jonne
