Audio measurement gear
gvl
SoCal
Depends on how deep down you want the measurement to go. For most normal stuff, a Scarlett 2i2 is more than good enough.
Thanks, it is 106dB AW, probably good for -100dB down, right?
SIY
Alfred, NY
Or better. I have no problems getting 20 dB below that with signal averaging and characterizing loopback. Pete's interface can get you another 10 dB.
Blumlein 88
Hi - question for ya'll relevant to this thread.
I do a large portion of my listening out of my OTL tube amplifier. I'd love to have an affordable measurement setup such that I can quantify the harmonic distortion profiles of various input/output tubes and see if there is a correlation to my subjective listening preferences.
Would the QuantAsylum QA401 be a good choice for this use case? The price is reasonable and it seems to be getting very positive feedback.
Also, I have never taken audio measurements before, so I will have to do a fair amount of learning. I am not an electrical engineer, although my first degree is in a STEM field (now work in healthcare), I'm confident I can figure it out.
Thanks!
If you are going to be doing speaker/amp level measurements the QA401 is probably a good deal. A soundcard and something else like the Pete Millet interface could work too. The QA401 is set up for your needs, and likely cleaner than what you are measuring. There is a question not resolved in my mind in regards to noise floor modulation, but that isn't going to be a problem for your purposes.
Blumlein 88
Any suggestions for a reasonably priced competent USB-based ADC solution? I've been thinking about getting the RME ADI-2 Pro just because it is such a Swiss army knife, but can't justify paying the price for my modest needs.
Like SIY said, a 2i2 can do a lots. A 2nd hand Forte is a quieter cleaner device. You can get those 2nd hand for $200. But it is a discontinued interface which it is appears they aren't going to support in the future on the software side. The same ASIO drivers as offered initially. They do work fine with Windows 10 and the current Mac OS. Really clean microphone pres on this if you care.
I'd sort of like the RME offering too, but I just don't need it for testing. I'd like the quietest thing going, but don't really need it.
gvl
SoCal
What does the QA401 have additional to offer over say a Scarlett 2i2 ? Just better integration with the software measurement tools?
It has a scalar and software tailored for measurements. These things are very important.
Blumlein 88
I've not had hands on one. But it offers you the chance to connect speaker level signals without harm. You can do that with a 2i2 without possibly damaging it unless you create or get some sort of box to drop the signal level. It would be much more convenient.
L0rdGwyn
A sound card plus an interface like Pete Millett's will be able to get you capabilities to get those spectra at a very low cost.
If it helps, I wrote a series of articles on this in AudioXpress. Here's part one of the series, with links to the other parts at the end.
Thanks! I'll take a look at your articles and the possibility of using a sound card.
Thanks for the reply. I've reached out to QuantAsylum as well to hear their thoughts on my particular use case. I understand that it is probably overkill, but another appealing aspect of the QA401 is the total package and the included software.
gvl
SoCal
I'm considering the QA401 too as it is a good package at a reasonable price. The only bummer I don't think it can feed a DAC with a digital stimulus, or can it?
SIY
Alfred, NY
That's why God created USB ports and USB-to-spdif converters. :cool:
SIY
Alfred, NY
Use your computer to send the data. The QA401 can then be used to look at the output (I think- I haven't used one yet).
The 2i2 also won't send digital data. The card I used before it, the M-Audio 192, had spdif in and out and very good performance. Too bad it doesn't fit in my current computer...
gvl
SoCal
It would be nice if it provided an integrated solution that could send out a digital output and take analog DAC measurements with a push of a button. My understanding it can do it for amp testing, but not for DACs. That's what I wanted to say. From memory there is an option to send the test signal to the default Windows audio device, but unclear how well that works if it is not using the WASAPI exclusive mode.
SIY
Alfred, NY
If you can scare up an older computer with a PCI slot, the M-Audio card I used will do that (assuming you have software like ARTA or Virtins Multi-Instrument). I see them on eBay for $50-75.
gvl
SoCal
Well, here is a recent DAC evaluation application note for the QA401 using the option I mentioned before. So seems it can do more than I thought by enabling test signal mirroring to the Windows default audio decice:
https://quantasylum.com/blogs/news/rapid-dac-evaluation
They sort of imply they use the audio interface in exclusive mode, but at the same time they say changing the system volume changed the measurement results which is odd as if they were writing to the device directly system mixer should have had no effect. Also suspicious is the statement that you can change the bit depth in the Windows audio device settings which probably indicates the test signal may be subject to resampling by the OS.
Reactions: trl
Blumlein 88
gvl
SoCal
One other reason besides the noise floor that makes me want the ADI-2 Pro is the 768kHz sampling rate.
Reinhold
Germany
If you were considering the 2i2 right now, I'd pay a little more for the 6i6. Currently marked down at amazon and sweetwater.
https://www.sweetwater.com/store/detail/Scarlet6i6G2--focusrite-scarlett-6i6-usb-audio-interface
Has more outputs and has coax spdif input and output. For testing eventually those will be handy. But this doesn't equal the QA in potential overall usefullness imo.
is it possible to connect an external dac like topping d30 via spdif to the 6i6?
Rja4000
Liège, Belgium
Hi
I'm trying different softwares.
Tried Mi Pro, Hpw-works, SpectraPlus and a few others.
My goal is to be able to assess my ADCs and ADCs (Hi level).
For that, I want to be able to compare it to RME ADI-2 Pro FS as a reference.
That means 2 ASIO drivers with separate channels.
As an example, send to the RME analog Left and SPDIF right, while input is set to RME Analog L+R
Then I can loop back the RME, while evaluating another DAC fed by the SPDIF.
The 2 software's I end up with are Mi Pro and HPW-Works.
The later, I can't evaluate fully, since trial is hard limited...
And I don't see how I could automate it.
But Mi Pro gives me very different IMD figures.
There is 10dB difference between Spectra Plus and MI Pro regarding IMD.. and Amirm is publishing still other figures, while everyone seem to align on SMPTE IMD (60Hz+7kHz)
Any idea why?
First eval: my Motu 828mk3 is performing approx. 10dB worse than the RME.
Both for ADC and DAC, whatever software is used.
