Audiophonics Ncore 500 W / channel stereo amp
Defman
Scottsdale, AZ
I just received and hooked up a Audiophonics LPA-S500NC 500 W X 2 at 4 ohms Hypex Ncoreamp for the L/R channels of my MRX1120 using the pre-cuts. The center, surround and Atmos channels are still being driven by the Anthem. I ran Anthem room compensation to balance the outputs. Since I used the RCA to XLR cables, the L/R speakers were about 4 db down from before as expected. ARC calibration took care of it.
Dynamic range is awesome, from dead silence to 95 db plus crescendos. If I mute the input, I can keep my ear right next to the L/R speakers and I cannot hear any hiss or hum. After three hours of use the amplifier is just warm to the touch. I connected the 12V trigger to the trigger from the Anthem. Worked as expected by turning the Amplifier on when the Anthem turned on. I did not see any of the high frequency shrillness I have read about. I played my stock high dynamic range classical music selections ( Wagner overtures, Mahler symphony #2 first movement and my all time favorite Symphony, #9 from Anton Dvorak). They sound as good as they ever did in my previous dedicated theater room which was a Klipsch set up. Now I have KEF's across the board which is much better suited to my musical interests. I cannot comment on the clipping because that has never been an issue in my system.
For just under $800 and it comes with switchable inputs and a 12V trigger. It looks very well built. The only issue was it shipped with euro style (230V) power cord and 250V, 6 Amp fuse. I replaced it with a standard IEC 3-prong cord and changed the fuse. The company responded promptly to my concern and offered me a credit for the mixup. I plan to take them up on it. I did not open it up and look at the build quality. That is for a future date.
Bottomline so far: Awesome piece of gear which puts out 500W/Channel X 2 from a unit under 8 pounds the size of an elongated shoe box.
Zoomer
D
Defman
Scottsdale, AZ
Very impressed with the after sales service. Used their website. Prompt and courteous. When I contacted them about the power cord and the fuse, they offered me choice of replacement of the cords/fuse or a refund. I accepted a refund of 40 euros ( roughly $50) which I felt was fair and more than covered the cost of the replacement cord and fuses.
mdunjic
Here is mine helped with two additional Audiophonics nc500mp monoblocks to drive the woofers … nc502mp drive midrange and tweeter drivers
tsfreo
Western Australia
Hi, reviving an old thread to ask whether you found any heat issues at all with your LPA-S500NC after living with it for a bit. I'm looking at the same unit and just hesitating over whether to get it, or the HPA bigger box version which costs a bit more. I doubt I'll be driving my unit too hard, but weighing up getting the dual mono with heat sinks (and extra $350AU or so all the way to Australia....).
yllanos
BAQ, Colombia
Hi.
I live in a hot and humid country (no seasons). I also own LPA-S500NC. No issues. It does get warm to the touch when you crank the volume up but that is it. It drives my Magnepan MMG no problems.
I think this model is now EOL and it was replaced by some other variation.
tsfreo
Western Australia
Hi.
Thanks for replying.
I did end up getting the LPA and it has been great (here in sunny Western Australia). No heat issues at all.
Mind you, I don't really test its limits at all. Pretty moderate volume use with reasonably sensitive speakers.
