- Joined
- Jun 5, 2020
- Messages
- 4,824
- Likes
- 3,757
That is a good result. It's worth it to put in the time to get that straightened out.
Curious as to why you replaced the plate amps, did one or both fail? How old are your subs.I recently replaced the plate amps in both my SVS S2000 subs and needed to run XT32 again to re-calibrate.
I have 2 SB2000's here and wondering about possible issues?
Appox how old were they?Both amps developed a hiss that I could hear from 9' away. SVS replaced both under warranty in very trouble-free fashion. The replacement amps are quiet.
OK, thanks for the info.Around 2 years. They always had some hiss, and it became progressively worse over time.
I thought the best way to handle multiple subs (at least without super expensive solutions) is the mindsp 2x4 hd anyway, which is external and independent of your AVR anyway?Was ready to pull the trigger on the Denon x3700h. Then I learned that no matter how migh in the range you go the Multeq XT32 handles only 2 subs. Audyessy offers a quad sub product which no AVR manufacturer has taken up to date.
So back to the drawing board I guess. Would have paid the premium for ease of use and future multi channel upgradability. Maybe wait 2 years before someone releases such a product?
Seems like the way Audyssey time-aligns sub is flawed and manual alignment is required (although it would be nice if someone could confirm to for the alignment of 2 subs, as I only checked the speaker-sub alignment myself), which as far as I'm aware is not possible to apply pre-calibration with Audyssey. When there's only a single sub then manually adjusting distance for integration with main speakers is possible, but it doesn't seem like you can manually align the subs to each other even with XT32 (which again should be done pre-calibration, so EQ is applied to the summed result of the time/phase-aligned subs).
Where do you place them? And how do you time/phase align them? Are you doing it old school where you play with levels and phase on each sub and keep iterating with REW?How many subs are you planning to use?
I have 3 and use an RCA Y splitter for 2 which my AVR treats as 1 sub. Works pretty well.
I've briefly thought about getting subs and had imagined that as one way of doing it, but good to confirm you can split the signal. Do you lose input signal power to each sub when you use a Y-splitter, is it halved?How many subs are you planning to use?
Yes, I can see how using a Y-splitter on inputs to the subs can reduce your configuration/tweaking options because 2 subs are getting the same signal (inclusive of any EQ within that signal, so they can't be individually EQ'd, but as you say there are probably other means of tweaking the subs rather than just on the input signal to them - sub positional placement and any kind of EQ options built into the sub itself)..Yes possibly but that’s only 3dB and you can get it back with gain adjustment.
What I intend is to have multiple subs in which each sub is individually peq’d so that the sum at the listening position is as flat as possible. Since each sub is dealing with a different acoustic environment each would need its own measurement and eq. Nothing wrong with copying the same signal and adjusting positions,phase, delay and level to find what is flatest at your listening position but we have more sophisticated ways of doing this now.
Interesting to know the different approaches, if I get some subs then I'll look into it more and choose what I think is the most valid method....preliminarily I think it would be a manual approach rather than using paid room eq software (eg Audyssey).Many sources claim that you shouldn't individually EQ them, but rather time/phase align them, set the level for total SPL (with both having same gain) and then EQ both the same. I suppose there is some logic to it (for example, if 1 sub has a peak where another has a dip, cutting that peak for both subs would result in a flat anyway), even though I don't really undrestand if the advantages outweight the advantages of individual EQ. In any case Audyssey XT32 time aligns the subs (although might not be in the best way and seems like you can't manually adjust it) and then EQs them both as one sub anyway. So if you time align with minidsp you get the same results as XT32 would give except you can manually time-align.
I suspect the reason is that eq-ing these subs is too complex for anyone to do “by hand”.Many sources claim that you shouldn't individually EQ them, but rather time/phase align them, set the level for total SPL (with both having same gain) and then EQ both the same. I suppose there is some logic to it (for example, if 1 sub has a peak where another has a dip, cutting that peak for both subs would result in a flat anyway), even though I don't really undrestand if the advantages outweight the advantages of individual EQ. In any case Audyssey XT32 time aligns the subs (although might not be in the best way and seems like you can't manually adjust it) and then EQs them both as one sub anyway. So if you time align with minidsp you get the same results as XT32 would give except you can manually time-align.
