Any tips on mic position if listening position is against back wall? Audessey says to measure at least 50cm away from the back wall but I’m planning on buying some acoustic panels for the back wall. Should I still measure 50cm away with and without panels?
As far as I'm aware most of the issues are with high frequencies, where the answers become complicated and you probably won't find a single one that's 100% correct. If you limit EQ to low frequencies, it's probably best to just place the microphone at and around where your head should be, at the height(s) where your ears should be.
