Totally irrelevant to this discussion. The 7702 was not compatible with Editor and only had a single subwoofer channel.
First, you're simply wrong on fact - 7702 had Audyssey’s dual sub “SubEQ” that is still unfortunately Audyssey’s latest attempt at multisub integration. It’s mentioned in multiple places in the review - read it. Hopefully Audyssey is reviewing what others are doing and will put their own spin on a modernized approach in future iterations of MultEQ X.
Second, 7702
in the context I brought it up is not irrelevant, but offered as real (spatial average of the same area, using
different measurement points than the calibration points) evidence that Audyssey's processes generally do a good job of fitting the average response over the measured area to a target curve. No, it was not compatible with the iOS app (which wasn't around yet) so the target curves available were limited to Audyssey's chosen ones.
If your going to that extent why bother with Dirac at all?
Please re-read my post above and you'll find a sentence containing most of the answer. The second part of it is, the room controls the sound of the system well above the subwoofer range. That's why cardioid or dipole upper bass can (but doesn't always) bring improvements as well - different interaction with room modes.
There are better, more serious DRC systems out there for the hands-on owner. And much cheaper.
Bullshit without a link, but if you do know of one with equivalent functionality to DLBC and meets my requirements (outlined below) that's cheaper than HTP-1+DLBC and I will buy it
RIGHT NOW and revert. Unfortunately, I'm not aware of a less expensive room correction system that:
(a) offers equivalent functionality to DLBC in terms of integrating multiple subwoofers into an immersive system with each other and with the other channels
(b) is available as a software plugin for an immersive AVR/P with Atmos decoding and Auro upmixing, or is available in separate >15-channel audio processor to be placed downstream of the AVR/P - i.e. does not require polluting your audio system with a general purpose computer for daily use
To my knowledge, the list below is the whole relevant market.
- Audyssey, which, as discussed, has inferior multisub capabilities and unfortunately this shortcoming has not been addressed in the current version of MultEQ X
- Anthem ARC, which is available in less expensive products and is excellent too but does not have any native multisub capabilities yet and is unfortunately not available in an AVR/P with Auro upmixing
- RoomPerfect ticks all the functionality boxes but is only available on more expensive immersive AVPs (and 2-channel products)
- Trinnov and Harman ARCOS have stellar reputations (I've not used either one) but...are not less expensive
Enough of this anyway. You get most of your toys on long term loan or flat out free.
For the record, I bought my HTP-1 at the standard price from the website without asking for anything else. I also bought my mothballed AV7703 at market price. Obviously review loaners of other AVR/P's, loudspeakers, etc were evaluated and returned.
Actually there isn’t a single thing that I can think of in our main system that was purchased in a manner other than on the open market at a publicly available price. Then again the HTP-1, AppleTV, disk spinner, and Harmony remote are the only “consumer” products installed. Everything else is “pro” or custom made.
