Basic Questions on Speaker Wires
Hipper
Herts., England
You can also buy flat cables that can go under carpet.
Sal1950
The Chicago Crusher
Central Fl
This is what I'm running here in 12g OFC, some very nice pure copper heavy dual strand wire.
https://www.ebay.com/itm/25-feet-OF...185185?hash=item41f854dc21:g:KOEAAOSwxCxT6loD
If your going really long or just want the piece of mind they now offer their TRUE 10g wire and even 8g, if I was doing mine over I'd get this now.
https://www.ebay.com/itm/25-ft-TRUE...279385?hash=item3f6a6a1f59:g:LzwAAOSwMgdX0H8a
https://www.ebay.com/itm/25-feet-OF...318859?hash=item3f7d7d898b:g:5tIAAOSwwNVTsfQv
Check around the Sky High store on ebay for the best pricing on the gauge and length you need.
bigjacko
For copper and CCA, regarding sound quality, isn't resistance the only difference? So given that CCA wire is wider than copper result in same resistance, would there be no any change in sound quality?
SKBubba
Having refurbed a couple of pairs of speaker and seeing the hookup wire inside, it makes me wonder about the need for my 12 ga. and 14 ga. speaker wire.
Sal1950
The Chicago Crusher
Central Fl
It's all a matter of distance. that 12" of thin wire inside your speaker won't change anything, but if you used another 20' of it, it would. The wire inside the voice coil is hair thin, but if you ran 20' of it to the amp and drove the speaker hard, it would turn red and melt!
Wes
distance & amps
BTW, if you put an amplifier close to each speaker, you solve some problems...
Z
zelig
distance & amps
... but add a bucket load of new ones.
Here is what I ended up buying based on the good information I got from you guys:
14 AWG x 100' copper wire $26
1/2" x 25' split loom sleeve $13
I started off wanting black cable because it was going to be visible, but discovered that I could get a much better deal on non-black cable. Using a single black sleeve I can "conceal" multiple cables, even though the final cost is about the same.
k3ejjgo7jpl
I hope it's not a problem if I revive this thread because I also have beginner questions about cables.
My question is what is the best way to treat the ends of the speaker cables, because pure copper may tend to oxidize. Here a user writes that banana plugs would be good:
Bare wires work well but are more subject to corrosion than banana plugs and therefore may need to be snipped and pushed back to clean copper every so often.
But I had read elsewhere that these banana plugs are not necessary if you do not want to change frequently the connected loudspeakers. Furthermore, banana plugs would mean another electrical transition that could lead to interference.
In other forums I have read that the copper cable ends are sometimes treated with corrosion inhibitor (similar to that war is used in a car) or even manually tinned so that the individual strands of copper are bundled. This would be, according to my understanding, but again disadvantageous because you would then have another electrical transition. (copper -> tin -> loudspeaker)
Is there a consensus here in the forum or possibly even a scientific study what is the best way to:
1. prevent corrosion at the copper cable ends of the speaker cables?
2. if banana plugs are necessary or if it is sufficient to connect the cables directly?
RayDunzl
Central Scrutinizer
Riverview FL
Grease. a little dab'll do ya.
Or, if you want to use an industrial standard:
NO-OX-ID-A
Spkrdctr
I wonder how much resistance a 1 or 2 mm coating has vs the bare wire?
Wes
the wire won't remain bare, but will corrode - that is what Tweek and the other polymeric conductive liquids prevent
Sal1950
The Chicago Crusher
Central Fl
I've had some early Monster cable turn completely green underneath the jacketing.
I think it had some interaction with the jacketing material or some outgassing of it?
Jbrunwa
Seattle
I suspect that when you tighten down the wire with the banana plug or binding post that it gets squeezed to molecule layer thin. That’s my understanding for crimped or compressed connections, correct me if I’m wrong. I use Pro Gold G100L. One tiny bottle will last me a lifetime.
mhardy6647
Hydrochloric acid from the PVC is the villain in your little set piece. :)
k3ejjgo7jpl
