Bass anechoic vs in-room
TurtlePaul
New York
Which suggests I’m missing something. How does “more 30hz” become 20hz?
Can you help me out? Cheers.
A room with room gain below 30 hz has flat-ish frequency response a above 30 hz and a +12 dB/octave gain below 30 hz. This means the lower the frequency the more gain you get. This nicely offsets the 12 dB/octave rolloff of a textbook ported speaker to create flat.
Every speaker benefits from this, but who cares about a speaker that rolls off at 70 hz in a room with gain below 30 hz. Yes the room will still produce this interaction but the speaker is ~20 dB down at the frequencies where the response levels out.
sarumbear
Yorkshire Mouth
Yorkshire Mouth
God's County - Yorkshire
Ah! Many thanks. Do I have this right?
A speaker that “goes down to 30hz” actually, and more accurately “only goes down to 30hz at +/-3db (or 6db). It still produces 20hz, just not very loud. The room boosts the “not very loud” bits. Is that right?
sarumbear
You are confusing closed box HP filter response with room gain. Room gain knee is almost never 12dB/oct. It varies with the room characteristics but often 6dB/octave.
sarumbear
I’m not saying anyone said that, I’m asking the question.
What makes you ask the question? If you study physics you will know that sound frequency does not change with reflections, unless you are moving the source.
BTW, if you haven’t studied physics, you will have problem grasping acoustics. I suggested having a crash course in physics.
Purité Audio
Industry Insider
Barrowmaster
London
The room may add gain and or cancellation on all bass below the transition frequency.
Acoustically measure your room, see exactly what you are hearing, reduce any room gain peaks, really that is all you can do unless you are willing to invest in massive amounts of membrane traps/resonators etc etc.
sarumbear
We don’t even know what does OP wants to achieve.
abdo123
Brussels, Belgium
my room behaves 12db/oct, but the subs have to be placed in a corner and the walls have to be really rigid just like the conditions in Rene's simulation.
(I live in a very tall building and my walls are basically really thick concrete and i still leak below 20 Hz)
Yorkshire Mouth
Yorkshire Mouth
You’ve been asked a question.
If you can answer it, answer it.
If you can’t answer it, don’t.
You’ve chosen instead to second guess my reasons for asking it. A quick review of this thread will demonstrate why this has led the thread to becoming derailed.
You appear to have been backed into a corner, and subsequently defensive, by others answering the question I asked; a corner which has progressively left you looking aggressive and confrontational, because others have taken a different approach.
The question which remains is simple. Why could others clearly understand my question, and answer it clearly, but you cannot?
It has become increasingly clear that others have fundamentally understood what I was asking, whilst you have not. The fault is therefore not theirs, nor mine.
Reactions: MAB
DJBonoBobo
any germ
sarumbear
How do you measure it and what is the f3?
sarumbear
If you haven’t measured it how do you know that it’s 12dB/oct?
F3 is the frequency at which the filter is at -3dB amplitude.
sarumbear
I have answered your questions. You said so yourself that you are happy.
Is that why you were frustrated and said “I don’t know how to ask it more clearly.
I don’t like argument for the sake of it.
sarumbear
I equalise my subwoofers to 35 Hz Butterworth 12db/oct like Rene’s simulation suggests and it measures pretty “flat” in-room. With some losses.
As the topic is the slope and as you cannot, understandably, cannot measure the response at 17.5Hz you do not know what the room gain slope is. You just used an EQ based on the 12dB/octave slope. The result maybe different and according to math should be different as there are not enough poles in the transfer function of the room effect to cause a 2nd order filter.
MAB
Portland, OR, USA
Yeah, he didn't understand your question. Happens so often online. I understood your question, and the answers you got.
gnarly
............... but the subs have to be placed in a corner and the walls have to be really rigid just like the conditions in Rene's simulation.
Yes, two crucial conditions for nearly every room-gain sim I've seen.
And to build on 'really rigid', that means all 6 box surfaces, walls floor and ceiling.
Oh, and let's not forget that means a box with no open hallways, openings to other rooms etc , and rigid doors and windows too.
Personally, once real world factors are taken into account, i think room-gain is most often wishful thinking.
Reactions: MAB
MAB
Portland, OR, USA
Totally agreed!
Also, to get 'room gain' at the listening position that actually takes their speaker's anechoic 30Hz roll-off down into the 20Hz range a couple other requirements:
  1. The room needs to have an eigenmode in the ~20Hz region
  2. That eigenmode needs to have a large positive value at the listening position
  3. Extra credit - that mode's frequency and amplitude and Q should nicely compliment the roll-off of the mains
With multiple subs and a reasonable room that can often be arranged.
With a set of full-range speakers set up for listening in an arbitrary room, even more wishful thinking.
I think it's the anechoic response that matters. Everything else is room and placement.
