Battle of RCA Cables: Mogami, Amazon, Monoprice
This is a review, measurements and comparison of a number of RCA cables from Mogami, Monorpice and Amazon Basics. The first two were kindly provided by a member. This is a subset of the cables tested:
And details of each:
  • Monoprice 1.5ft Premium 2 RCA Plug/2 RCA Plug M/M 22AWG Cable - Black
    • Purchased from: Amazon.com
    • $3.28
  • Monoprice 12 ft Premium 2 RCA Plug/2 RCA Plug M/M 22AWG Cable - Black
    • $10.38
  • Monoprice 25 ft Premium 2 RCA Plug/2 RCA Plug M/M 22AWG Cable - Black
    • $11.21
  • Mogami 12 ft Gold RCA to RCA Cable
    • Purchased from: B&H Photo
    • $105.90 for stereo pair (sold individually for 52.95)
  • Amazon Basics Male RCA Audio Stereo cable
    • 4 feet
    • $9.85
Ranking them in feel, the Mogami Gold easily takes the top spot with supple (but thinner) cable and nice metal connectors. Next is Amazon Basics which despite its thicker cable, is still pliable and has been so since I purchased it three years ago. Last and by far the least is the Monoprice. The cable is stiff as you can get it and connectors feel horrid in hand. So does the cable for that matter. It looks a ton better in picture than when you get it in person.
RCA Cable Measurements
I set up my Audio Precision APx555 analyzer to output 2 volts and analyze the same using its high-performance analyzer. I first ran it with its internal loopback (i.e. no cable) and then with each cable connected. Here are the measurements of all the cables. None showed any change in noise spectrum, distortion, etc. (some run to run variation is there with is immaterial):
Monoprice 2865:
Notice how despite is very long length, it is still transparent.
Monoprice 2866:
Monoprice 5346:
Mogami Gold:
I did not measure the Amazon basics for this phase but having done so before, it is the same as the above. That is, completely transparent in all respects.
"EMI" Interference Measurements
Owner wanted me to test for interference since he plans to use long cables. He pointed me to an online video test where the podcaster placed a number of XLR cables over a wireless charger and a couple of power supplies and recorded different levels of noise. He bundled all the noise sources together so not clear which was the one causing the noise. Owner was kind enough to send me a wireless charger to run the same test. I did but could not find any impact whatsoever on any of the cables. My own test of using an AC transformer though was quite effective in inducing mains noise.
Note that this is an ad-hoc test. Where you position the transformer on the cable may matter. As could the length of the cable, etc. But as a quick test, it does show us something. Here is the comparison of my Amazon Basics against Mogami Gold:
Note that the vertical scale is massively enlarged. The peaks are down at -130 dB or so and would be harder to see if I kept the top at 0 dB as I normally do. Anyway, we see that the Amazon basics in blue actually outperformed the Mogami Gold! So I picked that for comparison against the Monoprice cables which turned in the worse performance:
All of these cables are transparent for audio. While they did pick up some noise, that happened by completely touching a power transformer. And even then, the level did not rise to audible levels (although my AP analyzer may be more immune to this noise than your audio gear). So assuming you avoid touching a transformer to your cables, electrically all three cables have bandwidth that exceeds 200 kHz, and any noise or distortion is the result of the source, not the cable.
So it comes down to feel, pricing, etc. As I mentioned earlier, I absolutely hate the Monoprice RCA cables. I had bought some before and they were identical to ones tested here: just feel nasty and cheap although I am sure you could go a lot worse. The Amazon Basics remains my personal favorite in both feel and price. The Mogami has even better feel but you pay for that in much higher cost. Its thinner cable may have worse shielding than the Amazon Basics and hence the reason it picked up a bit more noise. I use Mogami Gold for XLR cables both in my main stereo system and for testing so it is hard to go wrong with it.
I know, not very exciting :). But it is good to get data behind what is a pedestrian part of our audio systems.
Overall, I am going to recommend the Amazon Basics and Mogami Gold. Stay away from Monoprice lest you demonstrate lower sensibility than I have in such matters! :)
fordiebianco
British Isles
Very reassuring. Will continue my morning listening session without cable-envy.
Thanks, @amirm
ernestcarl
Sadly, I have two or three boxes full of cables... I've got a lot of their RCA cables bought in bulk from years back. I don't want to use the word "hate" -- let's just say I dislike them thoroughly, and I'd rather use the freebie RCA cables one gets from random AV electronic purchases.
DSJR
Suffolk Coastal, UK
I bought an Amazon Basics 1m cable (under eight quid here) 'for a giggle' and had to laugh the other side of my face pretty damned quick! Going back to my sighted subjectivist dealer days, this wire suitably dressed up could sell for a good few hundred quid as it 'sounded' so refined with less 'hash' than the dealer sold stuff used to back in my darker times.
Seriously folks, I was shocked and it's not as if the Amazon *looks* cr@p either. I still have the remains of the 'subjective dealer' in me but as the head is taking over more now, I think I can deal with it.
Got to say for home made cables, I've tried some of the forum favourites of old, but do rather like the Mogami 2549 (incredible how our senses of touch and sight can dictate what and how we hear).
Kevbaz
West Yorkshire England
This reassuring to read, I stopped buying expensive cables a while ago and moved to Amazon basic cables and couldn’t tell the difference. So overall I’m happy to stick with my cheap amazon basics cables :)
Kevbaz
I do wish amazon basics would make shorter cables for stacking amps/DACs as their smallest size is 1.2 meters which is just too big :(
Kevbaz
Does anyone know of a reliable source of Mogami Gold cables in the UK.
Cheers
Kev
anphex
Berlin, Germany
I know it's not really the test case here but I had a few 20-30 € gilded RCA cables that had trouble with ground loop hiss and the the 5 € tin (or aluminium) cable didn't have those. To this day I cound't figure out why.
filo97s
Sestri Levante
Mogami construction-wise is by far one of the best cable makers, for sure they don't sell snake oil, and one of the most professional (they even specify measurements of their cables such as high frequency characteristics diagrams of phase, attenuation and impedance). If you buy it by the meter you can save a lot of money: one of their most used cable like the W2534 ships for 3$/meter, pair it with a pair of Neutrik Profi RCA and you're good to go, you have the best cable money can buy.
nyxnyxnyx
Awesome content! Now we have clearer reasons for people to consider whether they'd want to spend a lot on cables (especially when someone buys cables that cost way more than their sound system combined).
Is there any chance you would follow up with IEMs cables, and pair them with some established IEMs? As far as cables go, I believe the debate with IEMs cable is much more devoted than headphones and other accessory cables.
Count Arthur
Cheers
Kev
They don't sell the ready made Mogami cables, but they do sell Mogami cable, and you can pretty much have any length you like: https://www.designacable.com/audio-...coax-cable-angled-or-straight-connectors.html
I have some Mogami star-quad, balanced cables I bought there and haven't had any issues; although I'm just using them in a domestic set-up, so it's not like they have a hard life.
bloodshoteyed
n/a
i think it might have been this video by Podcastage:
