Behringer U-Phoria UMC202HD as a DAC
solderdude
The Neitherlands
Sounds like a groudloop.
It should be completely noise free.
Try it on another source.
S
Spinkicked
Unfortunately, I have no other sources that I can use it with.
How can I get rid of that problem?
solderdude
The Neitherlands
You need to find out where it comes from.
Can you connect the Motu to a phone ?
solderdude
The Neitherlands
when it works.. it works
S
Spinkicked
And then it stops working again. After a while it starts the same static noise. It actually makes a huge difference when I move the headphone cable. Whenenever I move the cable the noise decreases or increases depending on where I move it.
solderdude
The Neitherlands
Does this also happen when the amp is not connected to anything else ?
S
Spinkicked
You mean when just the headphone is connected to audio interface? No, it doesn't. It is strange. I am gonna return it, I guess. Just the Motu doesn't give the that sweet power as much as Schiit does but it still does the job just fine. And honestly, I couldn't really feel a quality increase in the sound, just the quantity.
solderdude
The Neitherlands
Yes, the only difference would be how loud it plays.
The noise is weird. Could be something in the Heresy doing this.
