Best DAC/Amp under $50?
calcium
Hey guys I recently bought Sennheiser HD 400 pro(560s repaint) headphones but their volume is so low. I can enjoy the music at low volume but when I use them on games like Valorant/Csgo I can't even hear footsteps properly. These are 120 ohm headphones with high sensitivity but still my cheap laptop's soundcard can't drive them. So kindly suggest some good DAC/Amp under $50.
I've seen iBasso DC03 PRO
Some Jcally Dongles
Shanling UA1 etc but can't decide which one will be best.
Joffy1780
Moondrop Dawn Pro looks like an excellent dongle for the money.
Joffy1780
pavuol
EU next to warzone :.(
unfortunately out of stock everywhere.
what do y'all say about jcally jm20?
Seems like a steal if it is a genuine CS43131 chip inside. Those Jcally dongles come at very aggresive prices, I'd be interested if there is some hazzard involved (craftmanship, life expectancy). If you have and option, I'd consider some used Tempotec/Hidisz/Shanling dongles as well, maybe some "older" proven chips like ES9218..
Both Shanling UA1 and Pro version seem quite solid imo
threni
/dev/null
C
calcium
It gets hot as per some reviews
alexandrul
Have you considered a pre-loved Fiio E10k? It's old enough so it may reach your budget.
Joffy1780
C
calcium
ZolaIII
I am a bit confused manufacturer specifies 110 dB @ 1kHz, 1 Vrms so even standard Realtek on board audio codec with about 1V output should have enough omph to drive them to about 86~90 dB average without problem (110 dB peak in bass). Which is actually pretty loud. Anyway Hidizs S8 and TempoTec Sonata HD Pro (which is pretty much the same thing tho S8 comes in better jacket and therefore perform a little better) can be found for less than 50$ and will give 2V output so go from whatever you find cheaper and more convenient to you. And they come with nice drivers (small and good working) for Mac and Windows (for Linux you don't really need USB audio 2.0 driver's tho even Windows has them from late 2020 H2 Win 10 it's nice and convenient to have proper ASIO one's for it).
C
calcium
Its an old i3 laptop from 2018 and I'm sure ASUS used the cheapest realtek soundcard in it. I have to pre-amp +7 in peace equalizer to hear footsteps in csgo/valorant
