Best DAC for less than $100?
DVDdoug
Probably the Apple dongle or whatever is built -into your phone, computer, or AVR, etc.
Joe Smith
If you can spend just over that amount, the Modi from Schiit or JDS Labs Atom+ are solid choices. The JDS one is powered, the other is powered either direct from USB or small wall charger...
C
carlmart
I'm looking for better options than the Topping D10. In the same price range.
AudiOhm
London, Ontario, Canada
The Topping D11, in the prototype stage, available in the near future...
Ohms
raif71
Is there an E1DA with RCA analog outputs with line level preamp, and separate power supply input?
There is a site link in my previous post. Perhaps you can take a look at it for the amp specs you're looking for.
staticV3
USB input, single ended RCA line level output.
Best DACs below $100 with USB in and RCA out:
-Khadas Tone board ($80)
-PO100 AK ($81)
-Topping DX1 ($99)
everything else is >$100.
Dunring
Florida
New the Sound blaster X1 and 3.5mm to RCA cables. Used a Topping e30 or JDS Atom. Even a balanced D10b comes up on eBay sometimes.
Xulonn
Boquete, Chiriqui, Panama
What do you dislike about the Topping D10?
