Best DAC to pair with Chromecast
Sir Sanders Zingmore
Melbourne, Australia
Hi all, I’m after some advice.
I wish to move my headphone setup into a separate room from my main rig.
To do this, I’ll be using a chromecast Audio to stream. So I’m after some recommendations as to the best dac to pair it with.
No need for any amplification (I have this already), just a dac.
Thanks in advance
BillG
Auckland, New Zealand
The analog output of the Chromecast Audio is already quite respectable. Therefore, are you sure you wish to incur the added expense? Granted the DAC could be used for other sources as well.
https://www.audiosciencereview.com/...-of-chromecast-audio-analog-performance.4562/
P. S. If you do decide to forego a DAC, it's suggested that the high dynamic range setting be enabled within the Google Home application for the Chromecast... :cool:
It probably doesn’t really matter, but the dac on the chromecast measures a bit worse than my main dac (Topping D10) and that will probably bug me !
So if there’s a relatively cheap dac that can improve the performance, I’m happy to buy one.
deafenears
Sabaj D5 or Topping D50s? Both have optical inputs.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
Did you ever try it with headphones? I just did...what a wacky but competent device... I keep finding more things to do with it.
[/QUOTE]
BillG
I may have discussed doing that here, although I'm sure I did elsewhere. However I've not gotten around to it yet.
My interest in doing the experiment was to see if it could be used on-the-go with ones cell phone. This may or may not work, as the Chromecast Audio is usually used linked to a LAN and the Net. However, I do recall my own once still being visible stand-alone during a Net outage that occured at my home somewhat recently - I didn't try streaming to it then, though in hindsight, it would have been the perfect opportunity to test... :cool:
M00ndancer
Sweden
I use one of my CCA as a headphone amp with a power bank when I want to listen to music on the patio or around the house when I'm not infront of my computer. My phone lack power so the CCA is perfect for that task.
mirceat
The less expensive option would be FiiO Taishan.
And because HDR on CCA has been mentioned, there is a meaningful post on https://hydrogenaud.io/index.php/topic,110158.msg908860.html#msg908860:
"High Dynamic Range should be switched off in the Chromecast app for the majority of setups. From what I can tell, it does not do any dynamic range compression, it is simply a function to switch the Chromecast into full-power 2V RMS output mode, as opposed to a slightly weaker signal (1.4V RMS?) that is safer for equipment of unknown capability."
HDR option is therefore a simple line output level switch.
Willem
The analogue output of the CCA is really rather good, so I would be surprised if a cheap DAC will be better. See here for more measurements: http://archimago.blogspot.com/2016/02/measurements-google-chromecast-audio.html I was pretty happy with it playing through some Quad 2805 electrostats. My new RME ADI-2 is better, but that owes at least as much to its perfomance as a preamplifier, compared to my old Quad 33. So by all means, get a really good rather than budget DAC if you are using a very good amplifier and headpones, but with anything less, there is no point.
Indeed, in most cases you should avoid the HDR setting for the analogue output.
Willem
No as the earlier link showed this is wrong, even though Google makes it hard to know this. It has nothing to do with dynamic range or compression: it is only a switch for analogue output level, and there are measurements to show this. So for most gear, do not turn HDR on as there is a fair chance that the signal will clip the input of the amplifier. Since it relates to the analogue output level, there is no equivalent if you use the optical digital output.
BillG
Re: HDR on Chromecast Audio
If you're getting surprisingly/insufficiently low output when running it analog, turn it on. If not, just leave it off. And, yes... it did just boost the output voltage... :p
