Best MQA capable DAC without any Preamp Module?
pogballistics
Can anyone suggest an MQA capable DAC without any Preamp module. Looking at a budget of less than 500$
I am considering the Schiit series cos of the fact that they don't have a preamp module in them. However, the fact that they don't do any MQA decoding and rendering is sad for me since I do quite a lot of Tidal streaming.
Can anyone suggest something with good measurements etc.
solderdude
The Neitherlands
The 'pre-amp module' usually is simply digital attenuation. A soft/firmware feature rather than an actual extra circuit that would affect SQ.
Jimbob54
The MQA is the stinger- but the SMSL M500 V2 fits the bill. As @solderdude says , its a dig pre-amp but you can leave at full volume and dont let that worry you.
Not sure what else lives in that price with MQA- The Topping D90 MQA is over budget.
SMSL-Mandy
https://hifi-express.com/products/smsl-m500-mqa-es9038pro-dac
Recommend the SMSL M500 V2 DAC.;)
Racheski
Chicago
Ifi Zen Dac in fixed mode will bypass volume control and can decode MQA for $129. However, the Burr Brown chips do not measure well and Ifi marketing is obnoxious :facepalm:
pogballistics
pogballistics
Asked cos you mentioned the device so I thought you have it. The review says it doesn't measure well.
pogballistics
pogballistics
Customs is a big headache. They probably will charge a lot making this a very sad / bad deal.
m8o
"Preamp" actually means it can amplify. A digital attenuator utilizing attenuation native within the DAC chip is not a "preamp". Thus, the Gustard X16 qualifies. And is about the best MQA DAC for the money tested to date.
