Best small DAC/amp for 600 ohm headphones?
Head_Unit
My headphones for serious listening are ancient AKG K240DF which are 600 ohms. As such, it is a bit tough to get enough volume, especially out of say quiet classical or jazz recordings.
A friend gifted me the Monolith USB DAC which sounds a bit cleaner than my 2015 MacBook Air, and definitely cleaner than a series of iMacs I've had. However the maximum volume is still not enough, so I'm still looking:
- General use case is carrying this stuff around the house or into the back yard or front porch. (Airplanes I take noise cancelers)
- So no AC cord and must be quite small.
- Need more output than the 2 volts of the Monolith, probably like 4 volts
- Ideally the Mac volume control would control volume, though I guess buttons on the unit would be OK (not tiny ones!)
P.S. I was spurred by the Apogee Groove review here due to high output, but even at 600 ohms their 20 ohms output impedance and "current drive" give me pause. Might try $149 refurbished, if they are easily returnable.
Veri
Grace m9xx/m920 perhaps? It'd be perfect if you can find a used deal that's in good shape.
H
Head_Unit
Wow that looks very nice, but large for my purposes and needs AC power.
H
Head_Unit
So I'm supposed to buy this for $65 and then sell to 120 ASR members for about $145 on eBay?
No, you're supposed to buy the minimum 10 for yourself, then you construct a special rack with custom operating system to run them all in parallel, to reduce noise and distortion...:p
