Best streamer?
ErVikingo
FL USA
I can’t do a proper search on the review section. So what is the best streamer?
I am happy with my Wiim Pro + D90SE but wonder if there is something better.
BTW, are there instructions on how to update firmware on my D90?
Purité Audio
Industry Insider
Barrowmaster
London
Better sounding almost certainly not at any price, different/added functionality perhaps.
Nutul
to remain in the same pool... the Pro+?
Acting on the DAC has nothing to do with improving the streamer... maybe you meant "how to improve my streaming listening experience as a whole"?
ErVikingo
ErVikingo
FL USA
Yes @Nutul better streaming experience as a whole. Thanks for adding context.
And info on updating the D90? All I find is incomplete.
somebodyelse
The only difference is the internal DAC, so no change when used with the D90.
The 'streaming experience as a whole' part is so dependent on which services you want to use (if any), how you use it, and personal preference that nobody can answer for you. Some will swear by Roon. I'd go for LMS and a mixture of piCorePlayer for some endpoints and squeezelite running on other linux boxes (HTPC, desktop, laptop) for others, with a phone as a remote. A Pi will give you lots of options to try at the cost of some time, but not all proprietary streaming services will be supported. Some think the Wiim does it all just fine.
Timcognito
NorCal
For the money WiiM seems the winner, for the experience with navigation, PEQ, DSP and music discovery Roon is best. IMO
ErVikingo
ErVikingo
FL USA
In that case, get better speakers and add effective room treatments. Even better, get DIRAC.
Thanks, I'm covered on the speaker, equipment and room treatment departments!
ErVikingo
ErVikingo
FL USA
ErVikingo
ErVikingo
FL USA
tonapo
I am a Roon lifetime user, its been my best hifi purchase I think. There is a trial I think, so you can try before you buy.
