Best way to add a center channel
JoachimStrobel
Germany
If you want center voice to end up in an extra loudspeaker under your TV, then you could consider an old analog Dolby surround system. The better ones had an active matrix steerer that would kind of capture sound that is made for the center. In another step you could find a hdmi switch that feeds that center channel via HDMI into your TV, avoiding an extra amp&speaker
sarumbear
What is the recommended way to add a center channel to an existing 2.0 system connected to a TV through HDMI ARC?
My amp has HT passthrough. However, it seems excessive to get a 7.1 AVR with pre-out (it probably won't fit into my cabinet) just to add one channel.
Is there something like an active center speaker that:
  1. takes HDMI ARC input
  2. decodes surround formats
  3. extracts center channel and plays it
  4. output L and R through RCA
One would think many people with a 2-channel system will want to add a center speaker for better TV dialogs.
Alternatively, who makes the smallest Class D, 3.1/5.1 AVR with pre-outs? I have space for half-width, 2U or maybe 3U at most.
Centre speaker is fed from a separate channel of the sound track. When you listen in stereo you are hearing a mix down. The only correct way to feed a centre channel speaker is to decode the surround track along with LR.
subframe
What kind of HDMI switch would this be?
JoachimStrobel
Germany
The catch is that you need a Videostream to go with it. I have an old (S)VIdeo to HDMI converter that allows me to feed in any analog audio to go with it. Another option is an Oppo 103 that would take an analog audio input and feed it to the hdmi out adding a blank video stream. It is a bit a non-trivial.
subframe
non-trivial indeed. All I really want is something that will decode 3.1 from HDMI and present those channels on digital outputs so I can add a center channel using my own DACs and amps. I don’t need a receiver with 16 channels + amps, 8k support and 11 HDMI inputs…
But such a thing may not exist!
Holmz
Australia
Ok - Why?
What do you expect that the center channel going to bring you?
subframe
Ok - Why?
Ok - Why?
Improved center image for people sitting on the sides. In my situation, people sometimes sit far left and right and fairly close to LR speakers. It’s a living room, not a dedicated theatre. Anyone sitting there gets highly localized audio from the closest speaker, throwing dialog off and making it weird to watch movies.
Holmz
Australia
OK.
For 2 people it is not really an advantage as both are near the middle, unless the relationship is rocky.
I also have a living room with a HT/2-channel so I know what you mean…
The other thing is that many center channels have a piss poor radiation pattern… WMTMW and MMTMM can be pretty narrow.
So it takes some chin scratching to get one that is actually fit for purpose.
