Beta Test: DISTORT - audibility of distortions
maty
Tarragona (Spain)
JRiver MC v26.0.103 64 bits
maty
Tarragona (Spain)
You know, in my very optimized Win10 64 bits to play multimedia, JR MC 64 bits sound much better than Foobar2000 32 bits.
I need a 64 bit compilation. And I will pay for it, without any doubt, unless I have to mortgage for it ;)
Balle Clorin
I cannot get it to work. the tones are not altered at all, what am I doing wrong?
I pick a file. click on harmonictsand then hit the play button.. but the tone is still playing undistorted
Installed latest version, and restarted PC.
pkane
pkane
North-East
I don't see any distortion selected. You need to select some type and level of distortion, first.
Set the Even/Odd back to 0, then dial in the desired distortion by using the two sliders on the right to dial in some variable/adjustable distortion, or click on Custom... and then enter the desired levels of harmonic distortion.
Balle Clorin
so I have to select CUSTOM, I did not understand that. Thought I had to select distortion when markin gEVEN and ODD and giving a value.
Works now. Many thanks
pkane
pkane
North-East
so I have to select CUSTOM, I did not understand that. Thoght I dis select distiorion when markin EVEN and ODD and giveing a value.
The odd/even controls let you adjust the relative strength of odd and even harmonics (for example, you can turn off all odd harmonics completely). But the actual harmonic structure still needs to be selected using Custom... or the sliders to the right of the plot.
audiofun
If you add even order harmonics, they will produce asymmetric waveforms, and thereby produce a DC component in the resulting signal.
that's true. but the software should have removed the DC after that.
users can easily generate full level DC without even knowing it, and break their equipments.
pma
Prague
Even in such understandable cases, there is/should be an option to eliminate DC. DC is a problem in ABX test.
Talking about amplifiers, they must be protected against DC in their design!!!
audiofun
exactly. dc is audible .
there's menu to add a lpf to remove ultrasound, but there's no hpf to remove DC.
pma
Prague
Even if your amp is ac coupled, the DC in the file leads to audible click at the beginning, so ABX is then invalid.
pkane
pkane
North-East
Let me know what settings you were using. DISTORT will use pink noise to equalize levels and to remove DC between different settings.
audiofun
as long as even harmonics is selected, it will have DC.
and yes, output wave form contains dc.
same to your vst plugin.
mocenigo
Harmonic content is a side-effect of the non-linear transfer function applied to the signal in time domain. I don't see how it can control phase of individual harmonics, but I'll do some research.
It is the sign of the term with the corresponding exponent, if you expand the transfer function as a taylor series.
So, for instance f(x)=c_1 x+ c_2 x^2 and c_1 >0 has positive H2 if c_2 > 0 and negative H2 if c_2 <0, and so on.
mocenigo
DeltaWave beta-test was a huge success, thanks to all of you! This new beta-test is again, only for the brave and the curious :)
Introducing DISTORT - free software designed to help determine the audibility thresholds of various audio distortions with your own equipment, at your own pace, with your own music. Some basic instructions and installer download are available on the Distort web page:
https://distortaudio.org
Just like DeltaWave, DISTORT runs on 64-bit Windows and likes lots of memory to process larger files and faster CPU, if you like a faster response.
The basic idea is to shape the desired harmonic and noise floor distortion and then to apply it to any piece of recorded music. You can play the distorted file directly, using the play button, or save it as a 32-bit WAV and play it using your preferred player software. See if you can spot 1% THD!
My hope is that DISTORT can help answer some burning audio questions and help to dispel some persistent audio myths:
  • Is SINAD of 110dB audible?
  • Is THD below 1% audible?
  • Do even harmonics sound better than odd?
  • Do higher-order harmonics sound less pleasant?
  • Does SET distortion really sound good?
  • At what level does the noise floor or the mains frequency become audible?
  • What kind of music is improved by lower THD? Even harmonics? Lower noise floor?
  • etc., etc., etc.
My plan is to build more distortion generators into DISTORT over time, from different filter types to jitter, to variable group delay and some others. All with the same goal in mind: to determine at what levels these distortions become audible. Any suggestions on which ones you'd like to see first are welcome.
If you discover an error or a crash, a short description of what you were doing, a screen shot, and/or a log file (available from Help->Logging->View Log menu) would be very helpful. Please give DISTORT at try, and as always, I welcome all feedback and suggestions!
If you want I can try to make a macOS version - it all depends on whether you want to share the sources.
pkane
pkane
North-East
Actually, harmonics phase can be specified exactly at any specific frequency of the test tone. I’ve built this since I posted it, but for a different purpose. The same procedure can be used in DISTORT, except it’s almost twice as slow as what I have there now, so I didn’t want to make the software more complicated and slower in use. Taylor series is not used in DISTORT, by the way.
pkane
pkane
North-East
Probably not yet, as it’ll become difficult to make changes. Maybe once I feel the version is more stable. There are also libraries that are used for audio, charting, and computation that may not be easy to swap out or replace without major surgery. But thanks for the offer!
pkane
pkane
North-East
This may just be a measurement artifact. Here's the PK Harmonic VST plugin with significant distortion dialed-in, playing 1kHz sine wave, showing no DC:
Same settings used in DISTORT to play a 1kHz signal, also showing no DC:
