Beta Test: Multitone Loopback Analyzer software
pkane
pkane
North-East
pkane
pkane
North-East
I can't get a decent result with 8 (or 12, 16 and many other) averages. The last average always spoils it:
7 averages works all the time:
Is the test signal too short?
Here's a test with 96 averages....
Rantapossu
Here's the waveform (I zoomed the waveform in and found nothing. I also listened the result wav and it was clean):
And the result:
Changing the ASIO buffers doesn't help.
Here's the 8 averages with the 1 kHz sine, no problems at all:
Your 96 averages example is too much to verify the problem, here I plugged the RCA off at the 94 averages of the 96 while still running the measurement and the last two averages were calculated completely without the signal and with the floating RCAs and the result it's still decent:
pkane
pkane
North-East
And the result:
Don’t know how to explain this, as I don’t seem to have a problem here. Looking back at @Sokel ’s tests, he used 8 averages also with no obvious errors. If you can, please export and share the history record with the error and I can see what I can find.
Rantapossu
Thanks, I will do that.
It takes some time, I'll have to setup some kind of cloud account for that.
Rantapossu
Try wetransfer.com. You can upload up to 2GB without setting up an account. Just copy the link after uploading and post it here.
Ok, let's hope this works:
There's one working 7 average and one not-working 8 average measurement.
pkane
pkane
North-East
Got it, thank you. The 8 average shows the problem, so I can see what you see. Now I need to figure out what’s causing it ;)
pkane
pkane
North-East
Interestingly, I found what's causing the problem when I try to load your file from history, but I don't think this explains why it's not working for you since it only has to do with counting averages when a history item is double-clicked. I'll look at it some more, but now that I have it loading correctly from an mth file, I'm even more puzzled as to why it might not be working for you when running live measurements...
pkane
pkane
North-East
Can you please test this version: https://app.box.com/s/qbrh3czrvudclkqs9n8lm806k3hzmjx5
This has some unrelated changes that are not fully baked yet (always working on the next thing!) but I think it might resolve the issue with the last average in your measurements. Fingers crossed!
Rantapossu
It freaking works!
I tested with the following averages:
1
2
4
8
12
14
16
And all was ok!
There were problems with lower averages (Even with 1) too with the previous version, now the behaviour is completely different.
Do you know what was the exact problem or was this solution the just a shot in the dark?
I just tested the previous version with the virtual "ASIO Bridge and Hi-Fi Cable" and it averaged incorrectly with it too, so it isn't my sound card that was causing the problem. Just to let you know, if you want to replicate the previous result...
Rantapossu
And I found one of the new features very useful. I was going to suggest it to you, but now I don't have to ;)
pkane
pkane
North-East
Now that you found it, may as well test it :) although it's not finished yet (some of the sweep labels are not formatted correctly).
pkane
pkane
North-East
It freaking works!
1
2
4
8
12
14
16
And all was ok!
Glad it's working, and I'm glad you reported this! There was a condition at the end of the capture where the number of remaining samples could be computed incorrectly resulting in only a partial FFT with some data missing :oops:. That caused the overall average to degrade right at the end.
Rantapossu
I might have triggered this condition before too as far as I remember, but the latest test tone made it repeatable. I thought previously that it was the problem with the ASIO buffers, but now I know.
Thanks for fixing it!
Sokel
I see you've been doing some work!
I did occasionally had some problems too with 8 averages but it was random.
Let's see...
