Beta Test: Multitone Loopback Analyzer software
pkane
pkane
North-East
I know this is off the debug focus, but is there consensus as to when the aes17 notch should be used? Thx
Use it to reduce the effect of noise and distortions that are close to the fundamental in the THD+N and noise/N+D calculations. It's used to remove (notch out) the fundamental in some calculations of THD+N, but MT doesn't use it for this.
Moto
I understand its purpose, but am trying to understand under what circumstances it is appropriate to use.
pkane
pkane
North-East
When performing measurements using AES17 standard. According to AES Measurement of digital audio equipment publication:
Overview: Performing a THD+N ratio measurement
The test signal shall be a sine wave. The analyzer shall include the standard low-pass filter. The total signal level at the EUT output is measured and recorded. The fundamental component of the test signal present in the output shall be removed with the standard notch filter, and the unweighted level of the residual shall be measured. The THD+N ratio shall be the difference between the residual level and the total signal level, expressed in dB
Moto
Thx Paul, but with measuring devices like the AP, a real notch filter is being used to remove the fundamental as above and in REW and Multitone, a mathematical calculation is being done. Do you do it the same way as REW, i.e. remove 1 octave around the fundamental?
pkane
pkane
North-East
Funny, you're the second person in the last few days to bring up AES17 notch implementation. AP, while using a notch filter, is not exactly a standard since AES doesn't specify the exact parameters of the filter, giving a range of values. MT applies this in the frequency domain using 1 octave around the fundamental, so while this isn't going to match AP exactly, the result will be very similar.
Reactions: pma
DonH56
Monument, CO
I have to think the reason for the notch filter, a time-honored device to extend the dynamic range of a measuring system be it audio, RF, or light, does not apply to a SW implementation? The dynamic range is set by the signal capture (ADC) so what is the benefit of applying a notch filter in SW in this application? Help to find the remaining spurs?
Curious - Don
pkane
pkane
North-East
Curious - Don
I'd say it's primarily for standardization of the measurement protocol than for an actual advantage. There's no advantage I can see to applying a simulated analog notch in the digital domain.
Rja4000
Liège, Belgium
Curious - Don
You may want to have a look at this thread
In practice, the AES17 notch is usefull with digital measurement when the fundamental, through the DUT, an analog notch filter, or from the signal source, shows some spread around its base frequency.
In my case, that was due to the E1DA APU notch filter. I see that also when I use Victor's 1kHz oscillator.
If I measure my RME ADI-2 Pro in loopback mode, the results are identical with or without the AES17 digital notch.
Not at all with the APU or Victor's oscillator.
The AP also uses analog oscillator and notch for high accuracy measurements and, therefore, also requires the same.
I suspect the AES 17 standard includes this to allow use of such analyzers.
The question is: do they compensate for the narrower bandwidth in noise and THD+N calculations ?
Ok, we speak 0.3dB or so, but I'm curious.
As per the AES-17 standard definition, it doesn't seem so.
Sokel
Yes,that's about the drop either in loopbacks or measuring other DACs,0.3-0.5db:
with
without
Sokel
Ok,I finally measured my rig from side to side (6 meters cable from xover to ADC,everything as is) ,except power amps (be nice):
SINAD at 1Khz for highs and 100Hz for lows.
FR and slopes.
Sadly it's too hot for my ADC (see the -15db play gain).
What's impressive though,never been seen in any measurement is that everything can be visible at the same time combined thanks to @pkane:
(I honestly didn't expect it to work so smoothly in history)
DonH56
Monument, CO
A notch filter on the analog input makes sense to me as it lets you use more of the ADC's dynamic range. After conversion is when it makes less sense to me, where the signal is already captured and you can always process the data. A digital notch filter can suppress the fundamental but if the spreading around it was captured initially it will still be there unless you broaden the notch, which then suppresses the noise/sidebands along with everything else. Why not just zoom into the area you want to see and ignore the fundamental that way? Too much for my little pea brain to handle, I guess.
pkane
pkane
North-East
It makes sense to have an analog filter before the ADC. After the ADC conversion, an analog-type notch filter makes little sense, other than to be compatible with other measurement devices that use one before the ADC.
Moto
So we see spreading at the foot of the fundamental with analog oscillators or analog notch filters but not with dacs. To try to compare results with a consumer adc to an AP it would make sense to use the aes17 digital notch feature in MultitoneAt 1khz that digital notch is not “too” wide but at 10khz , digitally notching out 1 octave seems crazy.
So is the digital 1 octave notch only useful at lower frequencies practically speaking?
I’m sort of back to my original question, what’s the use case for it.
pma
Prague
2 different issues.
1. notch to extract fundamental to get better distortion resolution
2. to eliminate spectrum broadening near fundamental to improve N
Moto
2 different issues.
Ok but does a one octave digital notch in REW or Multitone at 10khz make sense?
Moto
But just by that greater absolute width, isn’t the absolute value of noise energy going to be more greatly reduced than in the 1khz case? So maybe ok for logarithmic calculations but not for absolute value calculations of noise.
pkane
pkane
North-East
I needed a break so decided to implement the units for the level sweep (@pma). Unfortunately, the setting is still called 'vertical units' in settings :) There's also more to work on in the sweeps, but at least this part can be tested now:
https://app.box.com/s/ue7ll9xmvwogst817x2l1xg09opvgy47
Guermantes
Brisbane, Australia
Ooh, sweeps. So will we be able to do room analysis soon? (only half joking)
This is looking fabulous @pkane -- I'm looking forward to comparing it to our Lindos measurement set.
pkane
pkane
North-East
Here's a real world comparison. The differences exist, but are very minor, and most within the measurement variations.
10k AES17 notch vs. 10k no notch, vs. 1k no notch, vs. 1k AES17 notch:
