Beta Test: Multitone Loopback Analyzer software
Sokel
I *think* that Log Chirps don't appear in the Freq response window.
Measuring with multitone 32 signal,etc does.
pkane
pkane
North-East
Rantapossu
@Rantapossu , you may also want to check the latest update. The scientific notation axis labels in Waveform plot should now be fixed.
Yep, it's fixed! Thanks!
It still stacks the unit texts however (The second item I reported before):
There seems to be something wrong with the displaying of the vertical units on the Waveform -graph...
Like this:
pkane
pkane
North-East
One more minor update to v1.1.11: https://app.box.com/s/ue7ll9xmvwogst817x2l1xg09opvgy47
  • Fixes the Y-axis label overlap on Waveform plot
  • Fixes the discontinuity at the end of a Native DSD measurement
  • Fixes an issue with the final measurement results not being computed properly when the preview option is turned off in settings
Guy.Cohen
Hi Paul,
Thanks for the latest version.
A question, maybe the answer is known.
A measurement that is done with calibration file, is saved in the history.
However, most of the time when upload from history MTA does not use the calibration file
to calculate. Sometimes it does, most of the time not.
Of course, I am upload the calibration file into the right place, and ask to recalculate with the appropriate switch (Icon),
but it does not help. Maybe there is a different way, maybe I am doing something wrong.
Best,
Guy
pkane
pkane
North-East
Hi Paul,
Best,
Guy
Hi Guy,
Calibration file must be in the same spot on the disk as when the original measurement was taken. That's where MTA will look for it when displaying history entries. Don't replace the calibration file or rename it, as then MTA will not find it. I'm using calibration files now for a lot of my measurements, and I've not seen a case where calibration was not applied for history records.
Guy.Cohen
Thanks, I will recheck.
I don't think I changed the location or name of the file or the measurements but I will check.
I let it do everything automatic.
pkane
pkane
North-East
If you can find a pattern that causes this, let me know. I'm not sure how to reproduce this - it works every time when I try it.
Guy.Cohen
OK, the following cause my issue: If I open the history window (watch icon) there is a difference if I double click on the requested measurement or check the vee check of the measurement and then ask MTA to recalculate. If I check the vee and ask to recalculate then it is using the calibration file
and everything as it should be. If I double click on the measurement it does not take into account the calibration file, even if I ask to recalculate.
Guy.Cohen
One more, I notice that to install some version of MTA (e.g., the latest) I need to first remove the previous installation (otherwise can't install).
Sometimes it works without removing, your installation process taking care for everything.
However, it does not bother at all.
pkane
pkane
North-East
Sorry about that. I keep the version number the same for all the preview/testing versions, which requires uninstall/reinstall. When I post a link to a box.com download, that's a preview version. I usually describe it as such. When I release a new version officially (on the Multitone website), that is normally assigned a new version number and will update previous versions automatically.
Guy.Cohen
Yes, of course, that what I guessed. Anyway it doesn't disturb at all.
Did you succeed to recover my glitch I have with opening offline measurement with calibration file (double click or check vee described above).
After one time I open from the check, and it uses the calibration file, it looks like it doesn't have more problem. I can double click and it will compute using calibration.
pkane
pkane
North-East
No, I'm afraid I still can't reproduce. Checking an item or double-clicking an item appears to always use the calibration file for me.
