Beta Test: Multitone Loopback Analyzer software
Hee
topping e50 / cosmos adc
It depends on the sampling rate.
Blumlein 88
I still get a poor result at 0 db.
Selecting WASAPI shared mode works much better at 0 db.
Blumlein 88
This is the -1 db result with WASAPI shared mode. I'm running both DAC and ADC on the same laptop for what it is worth. This is worse than having WASAPI shared mode unchecked.
Grooved
I never tried before this setting, and I just got the same thing than you, turning it on Shared mode greatly improve the result at 0 Gain, but at -1 or lower, they are worse than without Shared mode.
@pkane how is that possible ?
Blumlein 88
Here is a result with my Zen Tour for the adc. A slight improvement over the Babyface.
If I set the signal to 0 db I get a similar poor result in the 60 db range. Changing to WASAPI shared mode improves the 0 db result, but worsens all others.
Blumlein 88
You guys with the Cosmos ADC should try the loop back thing over at Gearspace. You can analyze it with Deltawave and see the score you'd get. It might get one of the better scores.
Here is where to download the loopback file.
Here is the thread on gearspace.
Here is a list of the results so far.
Grooved
@Blumlein 88
So you got better results with the Zen Tour. It's interesting because if I'm not wrong, the BabyFace has better results in DeltaWave than the Zen Tour, and as @pkane developed both DeltaWave and MutltiTone softwares, we should be able to find answers.
It's the same thing for me with one of my interface, I have a old Motu 828 MKII that is 4th in PK Metric results (-108dBFS, the result for this one in DeltaWave page being wrong as it was done with asymmetric loop), just behind ADI-2 Pro (-116dbFS), BabyFace (-110dBFS) and AudioFire 8 (-109dBFS). This MOTU performs average with MultiTone (better in 48kHz), but great in DeltaWave
Regarding the GS loopback test, I already tried with the Cosmos ADC, but I get an horrible result (-24dBFS in PK Metric if I'm not wrong), certainly because there is no sync with the DAC.
I will be able soon to sync it once I will finish my mod to get digital audio output. I tried without MLCK and it did not work, so hope my last try with MLCK will be OK
pkane
pkane
North-East
Cosmos ADC has a fairly high DC component, even after the firmware fix. DeltaWave removes DC by default, Multitone does not.
I’m not going to be near my computer for a few days, but will go through the reports and the results when I get back.
pkane
pkane
North-East
It's certainly the case, you should get better results because the D10b has the same DAC chip than the Tone2 Pro, are both balanced, and has almost the same measurement on ASR reviews.
The D10b is even a little bit better, but I think Amir did not update the Tone2 Pro after the firmware update fixed the small problem on the first one :
That said, did you tried to set the Gain on OdB in Multitone Analyzer ? Is your D10b producing a lot more distortion ? this what I get, and maybe @pkane can confirm something on it : if that's the case, does't it mean that no audio should be sent to the DAC reaching OdB ?
When gain is set to 0dB, the sinewave amplitude output the sound card is -1.0 to 1.0. That is if there's not intervening volume control, such as with a WASAPI device in shared mode.
pkane
pkane
North-East
@pkane
Just tried the same thing than above but setting the Tone2 Pro via ASIO, and it doesn't work now with 1.0.9 version
I didn't touch any of the ASIO interface logic in this update, but I can confirm that ASIO isn't working, as puzzling as that is! I'll fix it ASAP.
MakeMineVinyl
Santa Fe, NM
Did you perform a measurement? No charts are displayed until there's data to show...
I've not tried Win 11 yet, but don't see why it wouldn't work.
I tried to perform a measurement and there was still no display. I'll try again with my home computer (also Win 11) and see what happens.
***Just tried it with same negative result. The 1kHz tone is default, but that should result in a display, correct?
pkane
pkane
North-East
Sure, if anything's measured. Is there any result displayed in the upper right corner, like TD+N and measured signal level? I'll do some testing with Win 11, since that's an official version of Windows now.
MakeMineVinyl
Santa Fe, NM
No, I didn't see anything at all below the control bar/meter at the top. No numbers at the bottom, only ---
pkane
pkane
North-East
That sounds like nothing was measured then. Double-check the device selection. During measurement you should see the level display next to the record button showing input level in real time, in dBFS (green line that turns red when clipping).
MakeMineVinyl
Santa Fe, NM
Here's what it looks like in action (sorry for the poor resolution - Youtube messed that up):
Yup, I don't see any action. :confused:
MakeMineVinyl
Santa Fe, NM
I do see the green bar graph. Nothing else though.
