Rantapossu
- Joined
- Jul 21, 2022
- Messages
- 517
- Likes
- 365
Let's wait for 2 more guesses to continue to the next step of the reveal... Anyone else?
Thx. I think I follow your adjustments but don't understand why they are happening.In my case, which I think Sokel has in mind, it is how to do very low level measurements and know what the results really mean. In the spectrum graph of a single tone, the level shown is 6.02 db lower than expected. So at a minimum all I can say is if I adjust for that 6.02 db then the results are at the levels expected vs Full Scale. I more or less confirmed it works and Sokel did a test that appears to confirm it as well. It also agrees with what is shown in the results tabulation if you open it from the square near the upper right corner.
I have a guess as to why this is, but only pkane can confirm it or explain how I am misinterpreting the results shown.
If I didn't answer what you were asking, then be a bit more specific and I'll explain it as far as I can.
I'm not sure either. My earlier guess is related to FFT's. FFT's have a positive and negative component. As long as there is no DC shift, it is fine to discard the negative portion and plot the spectrum with the positive half of the FFT. Doing so means the signal will display with half the amplitude. It is suggested you simply double amplitudes to get the correct readout in terms of amplitude. Doubling amplitude is the same as increasing it 6.02 db. For most of the tests you would run you can select dbR in the settings, and it will reference everything to the highest amplitude tone which makes it a non-problem.Thx. I think I follow your adjustments but don't understand why they are happening.
C-O-S-M-O-S!Let's wait for 2 more guesses to continue to the next step of the reveal... Anyone else?
That's the practical side.Thx. I think I follow your adjustments but don't understand why they are happening.
Cosmos ADC?
C-O-S-M-O-S!
Measure it until it drops!
I'm not knowledgeable enough about the various processing going on inside Multitone to know if there is a good reason not to raise the amplitude displayed. It may simply be that Multitone doesn't block or remove DC and other factors make it a bad idea to double the displayed amplitude.
Let me ask something...
Does system (sound properties) volume affects ASIO?
It shouldn't I think...
Yet it does.
Edit: it affects only playback device,not mic,regardless the setting of "Set System Volume".
No,I'm talking about PCM with MT own signals.DSD output should not be affected by any system settings if you use a true ASIO driver and not one that routes audio through WASAPI or other audio interfaces.
Oh, you're talking about MT not resetting mic input level. Something I've had no problems with, but I can certainly look into setting mic input level, as well.No,I'm talking about PCM with MT own signals.
I'm not able to test DSD,it's output is too hot for E-MU.
No,no,I'm saying that I can control output volume through windows system properties even during a measurement while being in ASIO.Oh, you're talking about MT not resetting mic input level. Something I've had no problems with, but I can certainly look into setting mic input level, as well.
I think I couldn't do that in previous versions.
Mic is not affected,I tried.
Thing is that the output is Khadas,not E-MU.I think that the Windows system playback volume has always affected to the E-MU ASIO output volume. Recording level doesn't affect to ASIO for me too.
Not in other versions,believe me I have tried to match the outputs with play gain and it wouldn't let me,MT was in charge.
Now I can (and I don't know what is correct,it's handy this way but I had to report!)
