Beyerdynamic DT 880 600 Ohm Review (Headphone)
solderdude
The Neitherlands
nope.
solderdude
The Neitherlands
consider hereyago, after being banned, used the name 'weslife' and is not the weslife you know.
AdamG
Enjoy the Music your way…
Moderator
Reality
escalibur
It wont be pretty.
They still might not be the worst neither.
"This leaves 3 interesting pads for this headphone. The Balanced DT1990, Dekoni Elite Velour, Analytical DT1990 "
https://diyaudioheaven.wordpress.com/headphones/measurements/brands-a-i/dt-1990-pro/
Sharur
The thought of NOT using equalization to get a more neutral response is blasphemous.
After doing more research, I was reminded of this. You yourself state that the Harman target shows "preferred bass" and is not actually flat. Neutral bass would be a flat line like in Etymotic's curve.
Vini darko
Dorset England
Neutral bass and treble is a moving target due to hearing sensitivity vrs volume. Harman curve is heavily loudnessed and should preform well at low volume. However as volume increases it becomes just an ugly V curve.
Sharur
Are neutral and flat two different things?
buscon
Checking this review the distortion level seems to be quite low. Maybe because of different measurement methods, but now, who should we trust? :)
solderdude
The Neitherlands
Both as I test at 90dB SPL and Amir at much higher levels.
Beyerdynamic drivers don't like to be played very loud.
Lero
Italy
Eq and listen them at low levels and dt880s are perfect all day headphones. I Use them for general porpouse and gaming ( very good for gaming). When i want to listen music at proper level i grab my sundara ! They have super deep bass at low output but they like to distort very very easly when you crank em up. Pretty good detail retrival in my opinion tho.
They have super deep bass at low output WHEN EQed
