Bowers & Wilkins Formation Flex Review (Speaker)
Rate this speaker:
    Votes: 48 31.4%
    Votes: 89 58.2%
    Votes: 14 9.2%
    Votes: 2 1.3%
This is a review and detailed measurements of the Bowers & Wilkins Formation Flex lifestyle speaker. It is on kind loan from a member and costs US $499.
The form factor is what we expect these days but the B&W unit is heavier than others I have tested. And that metal ring with their name gives it some style. There is some kind of grid pattern behind the thin fabric as you can barely tell from the photo.
Main connectivity is through Wifi although Ethernet is also provided:
The interface is typical of these speakers with touch sensitive "buttons" on top for power/status, play and volume up and down.
Bringing the speaker to life was a nightmare as it always seems to be the case with these speakers. Manual says to down the app but doesn't give the exact name -- again a common mistake. I found it in the app store and installed it. I then went to look for it in my Android app folder but could not see anything starting with "B." Come to find out it installs as "Music | Bowers and Wilkins." I get why they do this but sure screws up discoverability.
Once there, the app at first recognized the device quickly which I was happy to see. It then tells me to touch the power button which I thought I did. But the app quickly forgot about the speaker and would no longer see it. Adding to this is the fact that there is parallax error and you can ever be sure if you touched the darn button. Or what its myriad of blinking or color sequence means. I restarted the app half a dozen times but it would not see the unit. I think I even power cycled the speaker and it still did not work. I finally pushed the reset button and this time it all worked to the end. What a nightmare.
Why on earth don't this companies put a proper display on top of the speaker to inform the user what is happening? Or at least like Alexa speaker from Amazon have some voice responses giving some feedback? It is not like this speaker is cheap at $500 and can't afford $10 worth of parts. Why or why I have to guess what those fade in an out of the indicator light mean anything??? Style over function it is....
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
Reference axis was the tweeter center as best as I could guess through the grill. Measurement temperature was about 62 degrees F (17 degrees C).
B&W Formation Flex Speaker Measurements
Let's start with our usual "spinorama" graph:
Bowers & Wilkins Formation Flex Measurement Frequency Response Ethernet Wifi Smart Speaker.png
I must say, I expected the response to be horrible but it is not. Instead, we have some shelving in two regions. I have to think they have done this for some reason. Then again we have a dip there and I can't explain why they would want that. As noted, directivity is decent so EQ should work even though such is unlikely to be used by the typical customer.
Early window reflections confirms the same:
Bowers & Wilkins Formation Flex Measurement Early Window Frequency Response Ethernet Wifi Smar...png
Putting the two together we get this kind of response if you used the speaker in a typical stereo room:
Bowers & Wilkins Formation Flex Measurement Predicted in-room Frequency Response Ethernet Wifi...png
There is no attempt to control directivity:
Bowers & Wilkins Formation Flex Measurement Horizontal Beam Width Response Ethernet Wifi Smart...png
Bowers & Wilkins Formation Flex Measurement Horizontal directivity Klippel NFS Response Ethern...png
I can imagine you want very wide directivity for such a speaker. So not controlling it is good in early part of the spectrum, but not so good in higher frequencies.
Vertical dispersion is not as important in home speakers but here, I would think it is important given that people put this speaker some place and move around/stand up and down to hear it. Sadly the response is poor in this regard:
Bowers & Wilkins Formation Flex Measurement Vertical directivity Klippel NFS Response Ethernet...png
When I powered on the unit, i had it on the floor and when I played the first track, I thought it was the worst sound I had heard! So audibility is there for sure.
I was impressed by low distortion of this powered speaker:
Bowers & Wilkins Formation Flex Measurement THD distortion Response Ethernet Wifi Smart Speaker.png
Bowers & Wilkins Formation Flex Measurement THD Percentage distortion Response Ethernet Wifi S...png
Some of the high cost you play clearly has gone toward better amplification.
Measuring these speakers is a pain since the analyzer can't control the unit. So I don't have full suite of measurements for you. But here is the step response:
Bowers & Wilkins Formation Flex Measurement Step Response Ethernet Wifi Smart Speaker.png
B&W Formation Flex Listening Tests
For my listening tests, I treated the speaker as a near-field monitor. I placed it on top of my equipment rack with the front of it aligned with the front edge of my rack and listened at about 4 feet/1+ meter. Listening angle was slightly above tweeter axis.
As is typical of speakers with elevated highs, first impression is of a sound with high resolution and good quality especially on female vocals which is where I start. Let that sink in though and in a few minutes you realize it is too bright. The point is brought home when you apply EQ to lower that high frequency response and then AB. My preference at least is for less brightness. So EQ came out:
Bowers & Wilkins Formation Flex Equalization EQ Frequency Response Ethernet Wifi Smart Speaker.png
The right two filters should be self explanatory. The one in bass I experimented with. With most tracks the increased warmth and more bass was welcome. On some others, likely due to room modes, it sounded boomy. So you may want to try that and see what your taste is.
Oh, please ignore the "RME ASIO" indicator. I just brought up the EQ to take a snapshot of the UI. Testing was done using Airplay to Formation Flex.
Speaker can get pretty loud as distortion measurements indicate. Pushed to max limit (volume 100), you get soft limiting, reduction of volume on deep bass notes but even then, it is not annoying.
What was annoying was this gargling/low level noise I was hearing in a few quiet tracks. I thought it was data loss related so connected Ethernet cable but made no difference. It was like a delayed static of the actual content of the track. Very odd but super annoying.
I can partially see where the more money has gone as far as designing this speaker. At the end though, it doesn't rise up much above average smart speaker of this type and in my view, doesn't at all justify its $500 cost. Combine this with poor usability and static/noise I was hear and you have me on the unhappy side of the fence here. As such, I can't recommend Bowers & Wilkins Formation Flex.
  • Bowers Wilkins Formation Flex.zip
Newman
The fact that the total early reflections curve has the opposite shape to the on-axis curve, will suggest a low preference among listeners.
pseudoid
I don't understand why it is so bright.
Frequency response shows a trough between 1k-3kHz and a sharp 10dB dip around 16kHz.
Doodski
I used one of those little speakers things that chat ya and do stuff and it was great for the patio. It was sharp as a bell and did not carry too far. We used it all times of the day at the wood stove in the back yard in the middle of a city of a ~million. Very handy that way.
jhaider
Every time I see a smart speaker review, it reminds me how ahead of its time the OG HomePod was. And today, with stereo/spatial pairing and the “less bass” EQ curve they’re better than they ever were when sold as new.
AndreaT
Commonwealth of Massachusetts
Undoubtedly high in WAF (wife acceptance factor) but low in fidelity of signal reproduction. A further demerit because a global company like Bowers&Wilkins does not make the interface simple and unambiguous for the user. If it gives trouble to Amir in the set-up, it would give nightmares to me.
A product to avoid for any focused music listening.
Axo1989
Sydney
... A further demerit because a global company like Bowers&Wilkins does not make the interface simple and unambiguous for the user. If it gives trouble to Amir in the set-up, it would give nightmares to me. ...
Normally I'd have a laugh at another episode of 'boomer meets app' but for B&W that's probably the core demographic, so they may be well served by prioritising some UI/UX work.
Maiky76
French, living in China
Hi,
Here is my take on the EQ.
Please report your finding positive or negative!
The following EQs are “anechoic” EQs to get the speaker right before room integration. If you able to implement these EQs you must add EQ at LF for room integration, that is usually not optional… see hints there: https://www.audiosciencereview.com/...helf-speaker-review.11144/page-26#post-800725
The raw data with corrected ER and PIR:
Score no EQ: 3.1
With Sub: 5.8
Spinorama with no EQ:
  • Not as Flat.
  • HF issue
  • lack LF
Directivity:
Better stay at tweeter height
Horizontally, better toe-in the speakers by 00 to 20deg a
EQ design:
I have generated two EQs. The APO config files are attached.
  • The first one, labelled, LW is targeted at making the LW flat
  • The second, labelled Score, starts with the first one and adds the score as an optimization variable.
  • The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
Score EQ LW: 5.0
with sub: 7.5
Score EQ Score: 5.7
with sub: 8.0
Code:
B&W Formation Flex APO EQ LW 96000Hz
May162022-103930
Preamp: -3 dB
Filter 1: ON HPQ Fc 56.46,    0.00,    1.35
Filter 2: ON PK Fc 118.83,    -1.26,    1.64
Filter 3: ON PK Fc 625.50,    -1.82,    1.42
Filter 4: ON PK Fc 1298.24,    -1.20,    4.89
Filter 5: ON PK Fc 2102.22,    3.24,    3.93
Filter 6: ON PK Fc 3860.80,    -2.46,    1.62
Filter 7: ON PK Fc 6314.20,    -2.66,    3.59
Filter 8: ON PK Fc 13434.58,    -2.85,    4.27
B&W Formation Flex APO EQ Score 96000Hz
May162022-103756
Preamp: -3 dB
Filter 2: ON PK Fc 119.91,    -1.26,    1.54
Filter 3: ON PK Fc 608.50,    -2.14,    1.26
Filter 4: ON PK Fc 1299.74,    -1.94,    4.95
Filter 5: ON PK Fc 2060.46,    3.02,    3.62
Filter 6: ON PK Fc 3821.26,    -2.89,    1.24
Filter 7: ON PK Fc 6313.20,    -2.88,    2.54
Filter 8: ON PK Fc 12877.10,    -4.27,    2.82
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
Large improvements
The rest of the plots is attached.
  • B&W Formation Flex APO EQ Score 96000Hz.txt
  • B&W Formation Flex APO EQ LW 96000Hz.txt
thewas
Note: Rating meant for traditional monopole speakers.
Preference Rating
SCORE: 3.2
SCORE w/ sub: 5.8
Frequency response: +/- 6.5dB 50Hz-20kHz ; +/- 5.4dB 80Hz-20kHz
Funnily measures more neutral than their here measured "serious Hifi" model
I wonder if this is subcontracted out!
Jukebox
I would argue that it measure better than the majority of their hifi speakers :)
Bavaria, Germany
Hi,
Score no EQ: 3.1
With Sub: 5.8
  • Not as Flat.
  • HF issue
  • lack LF
Directivity:
EQ design:
Score EQ LW: 5.0
with sub: 7.5
Score EQ Score: 5.7
with sub: 8.0
Code:
May162022-103930
Preamp: -3 dB
May162022-103756
Preamp: -3 dB
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Large improvements
Neat plots! What tool did you use to do them? Does this tool also calc the preference score?
ZolaIII
It's not all that bright. I mean it is bright up to two hear able levels in upper mids, deap is a bit early in mids and it's one lv up at 12 KHz (one lv is 1.5~2 dB depending how you can distinguish it individually), 16 KHz don't matter much for most people and little to the most recordings. The 12 KHz peak is offending and should be brought down 2~3 levels (depending of hearing state) along with everything above 9 KHz. Short answers is Tinnitus. Until I sow actual pool results regarding this medical state hire it whose mystery to me. I did experience it but it's still rare to me (when I get serious inflammatory processes or so). I still prefer slight bost in uper mids - female overtones but that's my preference.
Dennis_FL
Venice, FL
" ... interface is typical of these speakers with touch sensitive "buttons"
I know what you mean. I bought a Sonos Move for use in our Lanai and it had those same buttons which are difficult to navigate.
One day, when returning from grocery shopping, the speaker was blaring at full volume. This happened a couple more times and I got Sonos tech support involved. They had me do numerous tests and the darn speakers continued to blare (but only when we weren't home).
One day, I solved the problem. On top of the speaker was a gecko, dancing and tapping his foot on the volume up button. I presume it was a sexual high since his bright red sack in his chin was inflated.
I informed Sonos's tech support and the technician said something like "I've been here 40 year but this one is ......"
I had a cell phone video (pretty poor as it was a hurried attempt) that I sent to America's Funniest Videos but they didn't use it.
DudleyDuoflush
That's a good point. I often wonder if it would be worth reviewers publishing their hearing profile so consumers can compare it to their own. What's bright to them might not be to me, or vice versa. I have tinnitus and anything above about 11 kHz is severely impacted. My EQ settings must sound horrible to someone who can hear properly full range.
The proper measurements on this site do help massively.
AudioSceptic
Northampton, UK
Yes, the HomePod seemed a bit pricey, but compared with this B&W product it was a bargain.
Edit: £319 from Richer Sounds doesn't seem as bad as $500...
