- Joined
- Jun 10, 2018
- Messages
- 6,366
- Likes
- 9,535
Many, I fear, test the LS50 on a piece of furniture, that is, without independent supports and keeping the appropriate distances.
And yes, much better with sub: -79 Hz at -3 dB. Q100: -49 Hz at -3 dB (and front bass-reflex).
But the LS50 weigh 50% more, which helps a lot, as I have verified with my Q100 (which now weighs more than the LS50).
- En off topic -
Well someone must have mistaken me for a piece of furniture and tested the LS50 on my head. I tried the LS50's on a 36" high wall unit and they sucked, so I agree with you there.
As for increasing the mass of your Q100 it might or might not be an improvement because it depends on how that mass stiffens the enclosure. The LS50 has the strongest/stiffest enclosure I have ever run across. If you rap you knuckles on it you get sore knuckles and nothing else. The front baffle is made out of cast something or other with cement or whatever in it. It is held together with four long bolts. The Q100 is a decent, reasonably priced speaker, but that's it.
